installing gauges
   / installing gauges #1
speedy2
yanmar ym1500
Is it a good idea to pull fuel tank on ym1500 to get to the back of the dash to install oil pressure and temperature gauges? Thanks Speedy2
   / installing gauges #2
Didn't have to on mine. There is plenty of room to work with everything in place.
   / installing gauges #3
Nope. Plenty of room to work on the 1500. I've installed battery volt, oil and temp on mine. Only thing I did was pull the steering wheel to drill the holes.
   / installing gauges #4
i didnt even pull the wheel! i found more than enough room to drill and work
   / installing gauges #5
I was able to drill holes and work with everything in place as well, ym2210
   / installing gauges #6
... if you have small hands! ....:D
although I have not installed new gauges on my 180D; and Id like to; its a good idea; I have had the front plastic dash off to repair wiring; I could not access the wires properly with it in place and never managed to get the steering wheel off after much WD40; puller, grunting and even tried hammering a chisle between the steering wheel and the housing to no sucess ... only reason I got it off was it was a broaken dash at the steering wheel.
2025 Star EV Capella Electric Cart (A51694)
2025 Star EV...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
KUBOTA ZD1211 (A53084)
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
Miscellaneous Kitchen Equipment (A53117)
Miscellaneous...
