Installing cattler guards- any tips ?
   / Installing cattler guards- any tips ? #1
bcarwell
Austin, Texas
Kabota 7500DT
I've got some heavy 10 x 10 cattle guards that are "box" style with metal sides all around that are about 1 foot tall. They are going in pretty tough, hard Central Texas dirt with limestone rocks randomly down about a foot and a half.
I was just going to dig a 12 x 12 pit about a foot deep for each, make sure its reasonably level at the bottom of the pit, and just slide them in- no footings, no concrete anywhere. Any tips on anything else I should do or consider (aside from wings I already know about) ?
For example should I dig down 1 1/2 feet deep and fill with 6 inches of septic gravel so there isn't a standing pool of water for mosquitos ? Or should I put a french drain trench perpendicular to the the road on either side ?
These Mommas are going to be a bear to "slide" in (5 inch pipe) and won't move once I get them in, so I don't want to be pullin' them up after installing. I assume over time they'll fill in with run off dirt or whatever I'll have to clean out but I don't think there's any way to avoid that.
Thanks,
Bob
Bob
   / Installing cattler guards- any tips ? #2
I've set 4 cattle guards - three of them I put in concrete footings (just small quickcrete footings) and one I put in in a hurry (cattle had figured out they could jump the cattle guard, so I had to make it wider in a hurry).
I just dug the hole, put in a little gravel that I had, and put in the cattle guard. It was always in my plan to go back and pull the guard and set some footers. That's been about 5 years and I still haven't done it. It has sunk on one end a few inches, but it's not worth digging up now (at least not yet).
I think you'd probably be okay to just dig the pit and set 'em. Adding gravel for drainage would be a good idea, and pipe to daylight is even better if you can get it. I have one that always holds water for a while because it's in a low spot and there's now way to drain it without pumping it.
Good luck.
   / Installing cattler guards- any tips ? #3
Have you considered setting them on the surface then building dirt ramps to drive up and over them? No digging necessary and no standing water. Just a thought.
Thanks for taking the time to reply guys. All very helpful. I don't think given my limestone problem I'm going to have much sinking so I'm leaning to just diggin' a pit and being done with it. Good suggestion about considering leaving it on the surface and just filling the edges whcih I hadn't thought of. With them being a foot tall and it being difficult to dig topsoil around here its almost a toss up trying to dig a pit or diggin up enough soil to fill the edges that are a foot high. But you did cause me to consider another option. Rather than digging a foot deep pit, only dig it 6 inches and use what I dug out on the edges. I think I may find its too difficult to dig a whole foot down anyway for 3 100 foot square areas. My FEL won't do it and I've had to use my post hole digger for a septic leach line. Wish I had a trencher. I just broke 3 pins on my post hole digger in one day trying to dig down 2 feet for a fence. Grrrrr......
Anyway, thanks again. I now have the confidence I'm not overlooking anything, never having put one of these things in.
Bob
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
