Installing a loader...How hard is it?
/ Installing a loader...How hard is it? #21
SPYDERLK said:
I have experience with a Woods loader installed on an L3450 by someone else. What a mess! Took me hours to make everything right. From what I see, non factory loaders do not fit correctly and need custom fitting to make a good installation. An experienced person will know where to look and what to do - otherwise much time is wasted and perhaps some damage done.
larry
Our Bush hog loader fit both tractors perfectly. (Same mounting kit) Nothing extra had to be done to get it to fit.
/ Installing a loader...How hard is it? #22
No shimming so that joints could draw up tight without bending something? No holes out of alignment? Better than I saw with the Woods.
larry
My Bush Hog FEL came in this week, and I opted to install it myself. I'm about 1/2 way done and am glad that I did it myself. So far I have one question. I have the line that goes from the loader valving to the fitting that goes in the fill hole for the tranny. The line is 90" long, which is really long in comparison to the size of the tractor. I read somewhere that it is usually routed under the operator's station. Does that mean that it goes toward the back of the tractor, around the seat and over to the valving, or under the tranny some how......??????????? It is on the left side of my gear shifter, and needs to attatch to my right hand control box.
Well I got my FEL installed in about 6 hours. Not bad for a first timer on a FEL I guess. I bled off the air in the system, and added about one gallon of hydraulic oil. I am busy making my ballast weight, and have a toothbar to put on yet as well. It's here, just got to drill the holes and bolt it up.:cool:
/ Installing a loader...How hard is it? #25
So that's about $50 an hour?
Sounds good to me....
jb
Yeah, ya know that sounds like a good pay rate to me! And, I got education in the process.;) I ought to ask my boss if he wants to start paying me that much.....LOL! We all know what that answer would be....:D
/ Installing a loader...How hard is it? #27
I'd say you did good Camo. It would have taken me a lot longer than 6-hours. Plus there would have been a generous amount of cussing to boot.
It was very straight forward. I was worried at first because the main manual had very few instructions in it. Then, as I unpacked the parts, instructions started appearing with each kit. Very easy to understand, and there was only one time that I used my floor jack to assist. Bush Hog did a great job. All of the bolts, hoses, and fittings were there, except for the one that you are told to buy from Kubota when you order the kit. Great job Bush Hog!:cool:
/ Installing a loader...How hard is it? #29
So where did it go?
Mike058 said:
So where did it go?
I ran it straight ahead along the back side of the firewall, and out the right side. It looks like a good location, so we will see. Just got the hooks welded on, and toothbar attached. My Easter project.:)
Like this:
Got tootbar and hooks on today...
/ Installing a loader...How hard is it? #34
Did you weld the tooth bar into place?
Also I read your other comment about needing ballast. We'll all be waiting to see what you come with there. FEL looks nice. I'm sure I'll be a nice asset to have around the house. And since you put it on yourself you won't be intimidated if need/want to take it off.
Wedge
Wedge
I bolted it on after drilling two 13/16" holes. I've got my ballast in the works in the picture below. I bought a CAT 1 top link that is just too long. I got to return it for a shorter one.
