Inner tube woes
/ Inner tube woes
The stuff for buildings is made to contain a lot of air for insulating properties I understand. What they use in tires is more of a “urethane rubber product“
OK, thanks for that. I'll check with local tractor dealers, local tire shop doesn't do it.
/ Inner tube woes #23
Hmmm.....interesting.
So what is this foam that weighs so much, is it like the stuff you spray into holes in a building? Can you leave the tubes in? Will it breakdown over time?
Just when I thought I was old enough to know everything :)
Different foam from what I gather....it has to be put in by a pro, and then cured 24hrs in a heated 'oven' (not too high temp I think). Supposed to outlast the tire. They left my tubes in and simply filled them.....I guess they do tubeless as well ? Wasn't cheap......they had a minimum charge of $49/tire, but given the number of times I've had to replace tubes over the 12 years or so I've had the tiller, and that is now OVER, I felt like it was worth it.
/ Inner tube woes
Thanks for that Andy - good info there :thumbsup:
BTW, we were over your way couple of years ago, nice area & people.
MAYTAG BRAVOS XL WASHING MACHINE & DRYER (A64281)
MAYTAG BRAVOS XL...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Wacker Neuson...
AUCTION STARTS HERE @ 9AM (A64276)
AUCTION STARTS...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
Caterpillar 963 Track Loader Service Manuals (A63117)
Caterpillar 963...
