Inner tube woes
/ Inner tube woes
The stuff for buildings is made to contain a lot of air for insulating properties I understand. What they use in tires is more of a “urethane rubber product“
OK, thanks for that. I'll check with local tractor dealers, local tire shop doesn't do it.
/ Inner tube woes #23
Hmmm.....interesting.
So what is this foam that weighs so much, is it like the stuff you spray into holes in a building? Can you leave the tubes in? Will it breakdown over time?
Just when I thought I was old enough to know everything :)
Different foam from what I gather....it has to be put in by a pro, and then cured 24hrs in a heated 'oven' (not too high temp I think). Supposed to outlast the tire. They left my tubes in and simply filled them.....I guess they do tubeless as well ? Wasn't cheap......they had a minimum charge of $49/tire, but given the number of times I've had to replace tubes over the 12 years or so I've had the tiller, and that is now OVER, I felt like it was worth it.
/ Inner tube woes
Thanks for that Andy - good info there :thumbsup:
BTW, we were over your way couple of years ago, nice area & people.
2014 CATERPILLAR 320EL RR EXCAVATOR (A62129)
2014 CATERPILLAR...
2016 Jeep Compass SUV (A61569)
2016 Jeep Compass...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2014 JLG 10054 SKYTRAK TELEHANDLER (A60736)
2014 JLG 10054...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
