Inline vs Traditional small Square Balers?
/ Inline vs Traditional small Square Balers? #21
....So, I also saw some Ford balers (traditional wide) for sale. Are these maintained by New Holland?
No. Anything with Ford on it in regards to a baler will usually be very difficult to nearly impossible to find parts for. That said, if the price was super cheap and the condition was excellent then I would not be afraid of one for a small operation assuming you have ability to be creative and make/retro-fit similar parts from other manufacturers as needed.
Usually from a low cost perspective the little operator is best served with sticking with New Holland or John Deere in a small square baler. Lots of them out there so price is reasonable, parts support both new and used is plentiful, and forum knowledge is also the most plentiful since they are by far the most commonly used.
/ Inline vs Traditional small Square Balers? #22
Did you tour the combine plant too?
Yes I did. I have been thru a couple of times, but it has been 2 years ago.
Gleaners, Massey, Challenger and they even were badging one combine a Fendt for Europe.
They still were using a Fiat tractor from the 70's tugging wagons around.
They are going to build a visitor center in the in the not to future.
/ Inline vs Traditional small Square Balers? #23
Whew,
What a mess of who owned what when, especially as sometimes a company will buy another company just to gain access to patent rights.
Did Fiat also own Oliver?
I would assume as companies merge, they would tend to drop redundant product lines. But, then what happens if they split off again?
Oliver was bought by White Motor Company in the early 60's with Minneapolis Moline and Cockshutt.
White continued to build each independent of each other until early 70's.
Interesting though, Hesston Mfg did buy Oliver baler line from White. The first small Hesston baler wasn't inline and was an Oliver painted as a Hesston. The first inline square baler built by Hesston was a large square. That was before CaseIH and AGCO. I think FIAT owned Hesston then. This is as I remember it.
/ Inline vs Traditional small Square Balers? #25
Ford combines were made by claas so i asume balers of the same era were too ?
/ Inline vs Traditional small Square Balers? #26
Not necessarily. Some Ford balers were Ford built. Some later ones were I hear were built by Gehl (Gehl has since ceased support for all ag product lines so no help there). I have also heard some balers were Class sourced. Regardless product support will be not existent through CNH which is why I alluded to being savy on either making parts from other lines fit, or modifying something else to work, or in a worst case making your own part.
I would only consider one if priced real cheap and even then the condition would have to be excellent. Being savy is not practical at all for a big time hay operator, but can be okay for a small time hay operator operating on a shoestring budget. Regardless, there is a reason why New Holland and John Deere have dominated the square baler market for the last 50-60 years in North America.
/ Inline vs Traditional small Square Balers? #27
Those ford balers must have been very popular at some time as almost every farm has one in the trees but they are "all" in the trees ?
/ Inline vs Traditional small Square Balers? #28
Those fords must have been very popular at some time as "every" yard has one rusting in the trees ?
/ Inline vs Traditional small Square Balers? #29
Never been around inline balers, just traditional style.
But looking at the pic that Clifford posted of the inline, can one assume that the hay is standing vertical in the bale chamber as to laying horizontal in a traditional ?
/ Inline vs Traditional small Square Balers? #30
Ford small square were built by Long and their round balers were Gehl.
/ Inline vs Traditional small Square Balers? #31
After reading the posts I am not sure I want to get into hay. I have a 25 acre filed just planted with grass hay. I have 6 horses and am tired of buying market hay each year. I have an Oliver 1855 diesel but no hay equipment. I was thinking of a NH model 273 or 276. Not sure what mower or rake I should get. Can someone give me some guidence please? Do I want a rotrary rake, a tedder?
/ Inline vs Traditional small Square Balers? #32
Quite a bit of the time... we already know what we want/need to do - we just need verification. I'm gonna guess that with 6 horses and a tractor - you've already got a pretty good picture of what/where/how and how much! :)
So, I'd like to ask you some questions.. maybe something that you haven't looked at in enough detail, yet. What kind of grass hay is the 25 acre field planted with? Pasture grasses are not (necessarily) the best hay (forage) material. Kentucky bluegrass varieties; for example. Excellent grazing, good regrowth, palatable, long-lived. Not a very good hay variety, though. Short, thin stemmed and becomes matted and difficult to mow and cure effectively prior to baling.
If you are able to harvest the 25 acre field for hay (good specie composition); do you have other grazing/pasture options while the field matures enough for a good hay crop?
Will you be able to harvest 2-3 cuttings per hay season? Do you have enough storage for all the hay?
How much annual precipitation do you normally get during a hay season? And how often does your area have adequate weather windows to prepare a hay crop? If the weather windows are short, irregular and oftentimes unreliable having a tedder and a MoCo (mower conditioner) can give you a 2 day edge on having a good crop or not.
Depending upon the type of hay - grass, alfalfa or a mix - the type of rake can be an advantage. If your hay is heavy, high leaf content and prone to twisting, roping or balling up; a wheel rake or rotary rake can be superior to a bar rake or side delivery rake - IMO. Wheel or rotary type can throw, fluff and better ventilate a heavy, leafy forage.
Do you have a good labor source? Small squares almost dictate that - hand labor. Your 1855 has enough Hp to work a good round baler as well as a good MoCo. And 6 horses will eat a round bale pretty fast!! With a feeder the waste can be manageable. Of course, handling a big bale requires some added equipment, too. Either a front loader for the 1855 or possibly a 3pt bale clamp.
AKfish
One cutting may still be sufficient.
Certainly you need to be able to arrange your property so that the hay field is not being grazed in the spring.
Part of it will also depend on whether you wish to purchase new equipment, or mess with used equipment, and how comfortable you are with repairing used equipment.
Around here, about 50% of the hay value goes to the land owner, 50% to the person mowing and baling.
It may cost as much as $3K to $5K to get someone in to cut and bale your 25 acres of hay. You would, of course, also save about $3K to $5K on purchasing the hay for the horses.
If you can pick up your haying equipment for less than $10K, you should be able to pay it off in a couple of years which is a very fast return on your investment. If you bale for neighbors, you would be able to pay it off much quicker.
If you invest $50K in your equipment, and only use it on your small farm, then undoubtedly it will break down before you get it paid off.
/ Inline vs Traditional small Square Balers? #34
man if i had to pay 3 to 5k to get a 25ac meadow baled id buy my own equipment.we bale 150acs once a year as it usually makes 200 bales or more in a cutting.an our baling cost is close to 6gs a year.thats why we bought a big 5 by 6 baler.you need a disc cutter an 8 wheel rake with a sq baler.
/ Inline vs Traditional small Square Balers? #35
Thank you AKfish. Great information and questions. Here is some addittional information. I have 20 acres for our horses that is split for pasture rotation. We bought the property next door and have leases it out to a dairy farmer for $1.00 per year. In return we were supplied with our 600 bales of hay for the season. It worked ok but quality of hay is poor and the dairy farmer seems to thing that my Tennesee Walkers are goats and will eat whatever his cows eat. In Michigan last year due to drought, hay was scarce, so this spring he just planted what he said was "a grass horse hay". I do not know what it is. Our plan was to keep first cutting and he can have 2nd and 3rd cutting. We were just informed that he is done with the arrangement and we are going to do it ourselves. I do all the repair on my JD, Bobcat and Oliver so I can do most basic repair. As this is a new field I do not expect much out of it and will be buying hay for this coming fall when pasture is used up. Sorry I just rambled.
/ Inline vs Traditional small Square Balers? #36
Thank you CliffordK. At this point I am thinking "good used" equipment" if I can find it. Just torn on models and type of equipment. We use square bales as they are portioned control and less waste. We have a couple of hay hogs that if I put out a round bale would eat till they explode. In fact one of our Walkers, I don't think we have ever seen his head up off the ground. We call him trash can!! Lol
/ Inline vs Traditional small Square Balers? #37
I agree with your math! We didn't use hay as a cash crop jut feed foe our horses.. We only use first cutting and let the farmer have the other cuts for his cows. Our thinking has now changed and we are going to make the investment for a bailer, rake and bailer. I live in Michigan and weather is fickle. Do I also need a Tedder ?
/ Inline vs Traditional small Square Balers? #38
ok you are going to make horse hay.id fert the 1st an 2nd cuttings.the 1st cutting really wont be horse quality hay.as your cleaning the field up from winter an spring.the 2nd cutting should be horse hay.you may want to spray the 2nd cutting for weeds.
/ Inline vs Traditional small Square Balers? #39
Iam 60 and my wife and I are the labor source. We have paid a couple of teens in the past to help stack bales in the barn but most of the time it's just me.
/ Inline vs Traditional small Square Balers? #40
We talked of that before but were told that first cut was better for the horses as it is not as rich. This was our horse vet talking. He has about 30 pacers so we listened to what he said. He is very old school however and the school of thought on what is best for a horse to reduce founder and colic is very broud. Due to drought this year in Michigan there was not much second cutting and zero third cutting. We were using anything we could get our hands on from our source.
PALLET OF TRACTOR WEIGHTS (A64278)
PALLET OF TRACTOR...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
7002SFL (A61572)
7002SFL (A61572)
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
