Injector cleaner
/ Injector cleaner #1
malced
France
Renault N72, Kubota B1200
I have a Kubota B1200 which is running a bit smoky.
Its nothing serious, but I am as sure as I can be that it is being caused by dirty injector nozzles.
In general terms I am rather sceptical of the claims made by the manufacturers of cleaning additives such as injector cleaners, but if they do work it might save me the expense of refurbishing or replacing mine.
Has anyone used these additives, and if so, have they lived up to the makers claims please?
/ Injector cleaner #2
I use Power Service(PS) diesel fuel supplement in all my fuel. Keeps things cleaned out and lubed as well as boost cetane.
PS has other additives that will help clean the dirty injectors.
Sea Foam also is an additive that works well.
Others on here may know other products that will work.
/ Injector cleaner #4
I also only use PS year round in all my diesel...no problems!
Sent from my iPhone using TractorByNet
/ Injector cleaner #5
Just my humble opinion ,,, but if the injector nozzle(s) are clogged up, I sincerely doubt any additive is going to clean them. Additives 'may' assist in minimizing build up from occurring but I have never personally used any in the 5 diesels I have owned over the past20 years...except in the winter to minimize geling.
/ Injector cleaner #6
My wife works for a diesel injection shop and they sell and use Stanadyne.
/ Injector cleaner #7
I've cured several "sick" diesels by adding a quart of automatic transmission fluid(ATF)to the fuel tank.
It really does work on some engines!
ATF can also be an emergency anti-gel additive when nothing else is available.
Good Luck!
/ Injector cleaner #8
Used power service exclusively on six semi trucks. Good stuff.
/ Injector cleaner
Thank you all for your replies. I was in the supermarket a few days ago and saw a can of Facom injector cleaner there so I thought I would give it a try. (Facom are a french tool manufacturer of similar quality to Snap-on).
I mixed it with some diesel and filled the tank. I then used the tractor to rotavate my veg garden. After about half an hours use the tractor started to blow out thick white smoke. This lasted for about 3 or 4 minutes and after that it cleared. Since then the exhaust is no longer smoky so I think the cleaner has had some effect. Time will tell if it lasts!
/ Injector cleaner #10
The smoke is an indication the Facom found some junk and broke it down and cleared it out. Sounds like Facom is much like Seafoam.
Good luck with it.
/ Injector cleaner #11
Might not even be useable for diesel, or something better may have come along, but I remember that 10 or 15 years ago Techron was the fuel injector cleaner of choice. I also like to use Power Service in all the diesel that comes thru.
And, our oil boiler guy put me onto a trick additive for cleaning and preventing heating oil (diesel) equipment problems from sludge and deposits. It is an enzyme treatment that is used like every three years in a 250 gal. tank. It just might do wonders for tractor systems, in the right amount, of course? I can't find the info at present, but I have some stored in the freezer.
1000 GALLON ALUMINUM NURSE TANK (A63291)
1000 GALLON...
CASE INTERNATIONAL 125 MAXXUM TRACTOR (A63291)
CASE INTERNATIONAL...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
Kubota ZG222 (A60462)
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
