Info on 1430
/ Info on 1430 #11
Welcome to the forum Robert.... while we "Red PTers" are in the minority, it is a growing segment on this board.
While all PTs are a unique and often underrated machine in the greater CUT community, their owners and other close observers value them for all that they do so well and if given the chance may step up the model line, but seldom go back to a regular CUT.
Welcome on board and appreciate your input.
/ Info on 1430 #12
Hay Robert that was a fine artical. Almost makes me want to trade up from my 422. Trouble is what to do with the 17 attachments. I really like my PT too. Happy tractoring.
/ Info on 1430
Thanks Robert!
I printed that out, it's such a great peice of information. /forums/images/graemlins/grin.gif
/ Info on 1430
Also, Robert metioned Bar Tires
Are they really better than turfs? How do they compare for traction? I'm planning on turfs because I don't want to hurt my grass and it does get soggy in the spring.
/ Info on 1430 #15
I now have bar tires on my 1845, after three years with turfs. I think the machine has slightly better traction in fairly deep mud, but not a lot. It's actually a bit worse on slick mud atop frozen ground. In snow, the bars are a little better in wet snow, but again not a significant amount, and no better on ice or dry snow. When I got the machine, Terry Estep at PT, and my main adviser, Bubenberg, told me that the turfs would do better in most conditions,and well in any, provided I kept tire pressures low. They were right. I now know that I can't drive around in deep horse manure & mud, in a swale on a steep hill, with a tree at one end, on bar treads either. /forums/images/graemlins/tongue.gif (Yes, Hans, close to the same place, but this time I got out by myself. I was further from the tree)
Turf tires are certainly better on the grass. They may be slightly less resistant to puncture, but on the 1845 and smaller the bar tires aren't the thick-walled skid steer types. They also are fairly thin, so I put in copious amounts of the bulletproof ultra seal.
If you're mowing a place you want to look nice, the turfs are better, and have few disadvantages.
/ Info on 1430
Thanks Charlie,
I'll probably get turfs. I was reading about how it's possible to "wiggle" out of sticky situations. I like that.
Another thing is the forks for the 1430 are around $1200. I think they're only around $600 for the 425. Is it possible to buy the 425 forks and weld on a 1430 attachment plate?
/ Info on 1430 #17
I think my forks are probably the same as those for the 1430. They are adjustable, thus requiring a frame with notches and dogs,etc. You might ask PT if they're willing to sell you a set of the fixed-width forks with a T12 adapter plate. You'd have to catch them at the time of a run of fork manufacture, since they do batches.
If that's not an option, they will certainly sell you the adapter plate - T12. It is $150. Forks of various sizes and strengths are available from numerous sources. Most junkyard forks are too heavy, but light ones for small tractors are around. With some cutting and welding, you can build a frame pretty easily to mount the forks to the adapter plate.
As we all know, if you really want to find out how reasonable a manufacturer's price is, build the product yourself. /forums/images/graemlins/grin.gif
/ Info on 1430 #18
FYI, I've bent my PT425 forks on several ocassions. My belief is that on a 1430 you would bend them like wet noodles. I wouldn't do it. /forums/images/graemlins/wink.gif
/ Info on 1430 #20
Let me suggest that if you want a strong set of forks, visit a forklift repair shop and see if they have a 16 in carriage with a set of forks that they will sell to you. I picked up a set for about $180.00 for my 1445. I expect they weigh about 250 lbs. Purchase or make an adapter plate and you will have a set of forks three times better that PT's. and are adjustable.
I also cut a one inch hole for a 2 in ball to move trailers and such. Works very well. They are good for about 3000 to 4000 lbs.
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
John Deere XUV825E (A61307)
John Deere XUV825E...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
