Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China
I added a cushion valve to my swing motor.
Where did you install it? Looks like you have some excess play in the house ring/pinion gears.
Can you reach the foot controls?
   / Importing and modifying a new mini excavator from China #1,163
I installed a bracket above the hyadraulic pump, the 15 models have a lot of empty space. I have yet to see one of these machines without play in the swing gears. When it's off you can move it a few inches back and forth. And yes, I can reach the pedals. I just turned twelve.
   / Importing and modifying a new mini excavator from China #1,164
Even name brand machines are like that.
Where did you install it in the hydraulic system? Add a tee and 2 hoses for each RV? Got pix of the RV you used?
I don't have that kind of slop in the ring/pinion gears on my XN08.
   / Importing and modifying a new mini excavator from China #1,166
I just put it before the swivel motor, no tee needed. The old hoses in one side and 2 new hoses back out to the motor. Here is the model for the RV DCRV45-06N. And you must not have a real Chinese mini if you ain't got that slop. It may be an effect of the cushion valve, I didn't adjust it much to find the optimal setting.
   / Importing and modifying a new mini excavator from China #1,167
DCRV45-06N
Very cool I wouldn't have had the exp to begin to try.
It does look like it works great, but did it slow the rpm at all (of house)? From the vid I'm guessing it's about 5 or 6 rpm now and I was thinking 8 or 9 might be stock?
This swing motor came tight, but sure aint after about 27gal gas.
Including arm slop I bet it's up to 5 inches now with bucket full out.
New motor to swap in now and a cushion valve seems like a nice addition.
(gonna disassemble old motor to find the slop).
___________________
On that HT 15, was it verified if you have 1 or 2 speed pump?
   / Importing and modifying a new mini excavator from China #1,168
___________________
The rpm can be increased with valve adjustment, I just have not adjusted it yet.
   / Importing and modifying a new mini excavator from China #1,169
I would not be surprised that coming EPA rules will make these little excavators unavailable for import in the near future. They stopped imports in the past until they shoe horned in the B&S gas (Already iffy in CA who wants to eliminate all small gas engines) and now the small Kubota diesels.
   / Importing and modifying a new mini excavator from China #1,170
You are right, at least we won't have kill switches on all new cars starting in 2026.......right????
378721 (A54865)
378721 (A54865)
*Selling at Royal Auction Zephyrhills, FL Location* 7 (A59228)
*Selling at Royal...
87in Toolbox/Workbench (A57453)
87in...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
