Implement Shed Build + PICS!
/ Implement Shed Build + PICS!
Dead for me also, really want to see them I am in the planning stages of building one and looking for ideas!
Let me know if I can be of any assistance as to materials, etc.
/ Implement Shed Build + PICS! #23
Looks really good CM but what is exactly a Alaskan slab?
Thanks, see my earlier reply to Eddie. I believe what I told him is what one is. I may get further details from my builder when I return home, this coming week.
/ Implement Shed Build + PICS! #26
I always thought an "Alaskan slab" was a floating slab, with a 8-to-12 inch deep reinforced surround to carry the building weight and "float" on the surface and not have to use "frost walls" extending down below frost level to a footer.
I defer to what you said. I'm no concrete/slab guy by any means, and what you said sounds about right.
I just couldn't remember how deep they poured the 'footers', and it might well have been just a few feet instead of the four feet I mentioned earlier.
Thanks for the input!:thumbsup:
Note to all readers: See post #29 below for a further detailed definition of a Alaskan slab.
/ Implement Shed Build + PICS! #30
Looks great want to do something very similar my wife also wants a screened in porch of the side of mine to over look the field so that would be a great option for the overhang, but less storage for me :( my tree line along my driveway looks like a used equipment lot so got to do something to get everything under cover.
Thanks! Good detailed description. I definitely have a floating slab on top of brought to site and tamped fill.
Thanks to all who've complimented the build. I appreciate it!:thumbsup:
jabelding, Since you're in Maine, your frost solutions are similar to mine, you don't want frost heaving your slab/building.
And, what I had to take into consideration as well, on the far end where the horizontal 6 x 6" beam extends out from the building toward my stream/ditch and woods line, for enough distance from the trees to the shed, so I can maneuver the tractor 180 degrees to enter/exit the building without hanging up in the ditch or the trees.
I suggest, in general, giving oneself more space than thought necessary around ALL sides of any shed. This prevents possible entry/exit issues that can be taken into account before but not as easily after a build.
Site orientation, especially in places like Northern New England, is crucial to good year round use of sunlight, breezes/winds, and shading as needed.
In my case this shed is oriented perpendicular to my existing barn, which is about 75 feet away. This gives me an area I can plow, toward the back left side of the shed, (alongside the overhang posts) and in the same direction I already plow the snow around the barn; toward the ditch and woods. By using 4 posts along the side of the shed for the overhang I can drive alongside the left side of the shed from the front through to the back with the tractor, without clearance issues for the shed/posts/tractor.
I can also go between any two posts at right angles to the left side of the shed for placement of frequently used implements during the Spring/Summer months.
To date, as I get used to the shed and the benefits it provides, I've stored my ATV trailer at the far end of the overhang with 2 Kayaks strapped to it's tailgate for wind mitigation. I can pull this trailer out from it's tailgate if needed, but otherwise it will await my putting it out in the 'yard' when the bad weather is over - June? July?:confused3:
In front of the trailer is my QA plate, on PT 2 x6 shim pieces so it won't freeze to grade. Then last, but often needing quick access, is my FEL bucket.
Shed orientation keeps prevailing winds/rain/snow off these items, mostly, and FEL bucket access is fairly easy.
ALL other implements are in the shed interior starting with at far end by tree line: Tree shear, on pallet,
Box Blade on pallet, then QA 7' HLA plow, sitting on slab.
I left flat area for additional temp storage along the entire right side of the shed, for my boat and trailer and anything else needing a place to park out of the way.
The overhead door at the away from the woods end is on a remote, so I can drive up, open door from tractor station, then get off tractor to hook up the plow and start banging snow away from the house/barn/shed. Yeah.
This winter there was very little snow bnging on my part since I left mid-Jan to go away to the islands and am returning tomorrow to hopefully sun and warm weather! Ha, Ha. Anyone who lives in N England knows better, right?!
On the interior, I ran all the windows on the weather exposed side to allow for them to be open in good weather to allow for cross vent airflow and cooling/ventilation as needed for painting, project protection inside as needed.
I have a hole in the loft area flooring for access via a extension ladder, when the far bay door is closed. I installed a railing on the closer to front of shed end to prevent falls into the shed slab floor area when working in the loft area.
I ran conduit into the back left corner and up inside the slab to allow electric/Cat 5E to a sub panel from the barn for lighting, etc. I ran all outlets along the interior overhang wall side and switches to control overhead lights/exterior floods/spots are in a 5 gang box to the right side of the left inswing man door. Exterior lights on each overhang corner re on RAB IR sensors, and additional under the overhang area lights are on an interior switch.
One duplex outlet protected by an arc fault breaker is located outside under the overhang in the far end exterior wall for use when the shed is closed or I need to run a cord into the driveway.
I hung 2 4' LED shop lights above the center of the slab, and split a 2 gang outlet box to feed them and the other side to run the overhead door opener.
The LED shop lights can be daisy chained together for about 8 or nine units, IIRC, and they are VERY bright and throw excellent light far and wide, especially from about 10' high off the slab. I ran a circuit on a separate switch into the loft to add LED shop lights too.
I don't plan to ever insulate the shed, and planned it that way. It is essentially a cold storage area, though I could put a space heater in at times as needed.
For materials we used Advantech for the flooring in the loft and on the roof sheathing, as I recall. The rest of the lumber is standard 2 x's, and PT plates, etc.
The roofing shingles are architectural Harvard Slate IKO, same as house front roof and barn main roof. All other steep pitched roofs are on site built standing seam metal roofing.
Grace Ice/Water Shield is used on all overhang areas and a roofing underlayment of polyE type is on all other roofing areas. I installed a ridge vent, even though no heat is in the shed, to provide better ventilation year round.
I don't like doing painting, maintenance on various buildings, my house included, so I went with pre painted Hardie board siding to match my barn. And PVC corner boards and all window/door trim.
This ups the cost significantly, BUT it saves on maintenance BIG time, so in the long run I feel I'm way ahead.
For instance I stripped and resided my entire house and new addition in 2009, as well as building a barn/apartment/boat bay, and I have yet to add a drop of paint to any of it. This year the house will need a cleaning and sanding and 2 top coats, possibly due to its exposure to the sun and the light green color it's currently painted.
The barn, which is the exact same red as the shed, looks brand new. No fade, no peel, no chalking whatsoever. It's amazing to me it can stand up to the incredibly brutal New England weather with out a sign of wear!:)
Note: It was pre painted at the factory, and given a top coat within 90 Days to maintain the mfg's warranty.
CM out, for now....
/ Implement Shed Build + PICS! #32
Ah yes. Now the links work and I got to see a beautiful job done on a really nice building.
Thanks, Bird:thumbsup:
/ Implement Shed Build + PICS! #34
CM I just came across this thread. Have tried the links with safari, firefox, chrome. No dice. Is there a way to see the photos? Thx.
/ Implement Shed Build + PICS! #36
I recently completed a shed build specifically for my tractor and its implements. Here is a description and some recent pics.
I just completed a implement shed with covered 'lean to'/overhang on the non-weather side. I have a LOT of implements and wanted to be able to drive in on one end and access implements from either end as needed.
I built 9' high overhead door openings, by 10' wide for possible future tractor upgrade, with 12' wide shed dimension, and same dimension for the lean to portion. The header is at 10' high over the gable ends, with a peaked roof with ridge vent, asphalt shingles, and Red Hardie board smooth finish with white PVC trim and corner boards.
On the far gable end I added a 6 x 6" PT post that extends out over the ground by about 6' in length to use as a point to hoist whatever I might want to lift off the grade. I can drill a hole in the horizontal post and add a chain hoist, or just throw a chain/rope over the post to haul items I might want suspended for inspection/repair/painting as needed. See pics below for view of this add.
The project was NOT cheap, but looks great, and does everything I could possibly want it to. I added a man door for entry on the non-weather side under the overhang, and even with 12' overall corner to corner exterior corner board width there is just enough room to move around inside with the tractor/FEL and backhoe ON! The building is 24' deep, and just fits the tractor/FEL/hoe. I did not plan to store the tractor in the shed, but I can if needed, but it's tight. I have to turn the hoe to one side to get it all in if needed.
Building it a couple of feet longer would have worked, but at more expense, and as my builder said, the 12' wide by 24' long and 10' beam height had some arithmetic advantages for cutting plywood, materials usage without waste, etc.
There is a upstairs loft area, accessible via a hole in the loft floor, and the overhang area provides more loft storage as needed.
I poured a Alaskan slab of concrete and rebar reinforcement, with floor drain for snow shed and water. Ran electric and Cat 5E out to it, and inexpensive Andersen insulated windows. One overhead door has an opener, the other could have at later date.
I sunk down 4' precast post piers, and set pinned 6 x 6" PT posts for the lean to/overhand roof beam to set on. The front gable end has two 5' high x 5 foot wide outswing 'barn' doors for additional access to the loft area.
https://scontent-mia1-2.xx.fbcdn.ne...=1c549395dfd21ede5c905cd3fb33d8ab&oe=598D4372
https://scontent-mia1-2.xx.fbcdn.ne...=32c3c82519664ac01879a2c83bd2804e&oe=5982E6D8
https://scontent-mia1-2.xx.fbcdn.ne...=2b4ef0de7efb8f65912b266f7b3cb479&oe=598011EA
https://scontent-mia1-2.xx.fbcdn.ne...=65654ac6829a693068e18d019357fc9a&oe=5982E28A
https://scontent-mia1-2.xx.fbcdn.ne...=5d9e3aa6e061e69293d24d66652a9cfc&oe=599181C7
Above are pics of the nearly completed shed. It really rocks. Part of the added costs was I set it in a location where I needed to bring in a LOT of fill to get the land up to grade. Had I set it elsewhere it would have cost much less in excavation and site prep costs. But this is where it works best in conjunction with other buildings I have on premises.
Enjoy.:thumbsup:
click on above ++++ to read what I get when trying to view your pictures
/ Implement Shed Build + PICS! #37
CDN = content delivery network, basically a temporary cache out on the network that facebook and others use to get some of the volume of bulky stuff like pictures and video off their main servers. These get cleared out fairly regularly.
CM will either have to find a link on facebook to post, or upload them to directly TBN...
/ Implement Shed Build + PICS! #38
Zero pics for me.
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
5ft. Wooden Cowboy Statue (A61574)
5ft. Wooden Cowboy...
