Implement hook up problems..
/ Implement hook up problems.. #21
It's possible lift arms don't spread as far apart. If stabalizer links can be temporarly disconnected that might alow flexability in arms.
I switched the lift arm pins on my implements from outies to innies years ago and haven't had any issues since.
JUST A LATE AFTERTHOUGHT AND ADVICE.. MEASURE ALL YOUR IMPLEMENTS FOR THE 27 & 1/8 OR WHATEVER BETWEEN LOWER PINS..I HAVE 6 IMPS AND ONLY ONE WOULD WORK WITH QUICK HITCH,,,SO PAT'S EASY IS THE RIGHT ONE,, THANKS TO ALL AGIN FOR REPLIES..
/ Implement hook up problems.. #23
I have both Pats on mine and extendable link arms. It’s a breeze.
/ Implement hook up problems.. #24
My dad is 74 and changes out in a jiffy on a 100 hp tractor. I don't understand your pain.
I AM 77 AND DON'T SEE ANY REASON TO-WRESTLE,PRY,PUSH,PULL,,TRY TO LIFT AND GENERAL TYPE FIGHT WITH AN IMPLEMENT IF THERE IS A BETTER/EASIER WAY.. MY OLD 48 8N HAS ADJUSTABLE BOTH LOWER ARMS AND IS WORN AND LOOSE,,BUT STILL HARD TO HOOK UP SOMETIMES..JUST ME,,YOUR WAYS MAY DIFFER.. HAVE A GOOD DAY ANYWAYS,,
/ Implement hook up problems.. #26
Well they have quick release ends for the lift arms. Which are different lift arms you can get. John deere has some square tubing/ square inner sleeve type that work good. Also there is a quick hitch available.
CASE 105C (A62177)
CASE 105C (A62177)
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
Club Car Emergency Cart (A64557)
Club Car Emergency...
1979 AM General 6X6 Truck (A65563)
1979 AM General...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
JOHN DEERE 6105E TRACTOR (A64277)
JOHN DEERE 6105E...
