Implement hook up problems..
/ Implement hook up problems.. #21
It's possible lift arms don't spread as far apart. If stabalizer links can be temporarly disconnected that might alow flexability in arms.
I switched the lift arm pins on my implements from outies to innies years ago and haven't had any issues since.
JUST A LATE AFTERTHOUGHT AND ADVICE.. MEASURE ALL YOUR IMPLEMENTS FOR THE 27 & 1/8 OR WHATEVER BETWEEN LOWER PINS..I HAVE 6 IMPS AND ONLY ONE WOULD WORK WITH QUICK HITCH,,,SO PAT'S EASY IS THE RIGHT ONE,, THANKS TO ALL AGIN FOR REPLIES..
/ Implement hook up problems.. #23
I have both Pats on mine and extendable link arms. It’s a breeze.
/ Implement hook up problems.. #24
My dad is 74 and changes out in a jiffy on a 100 hp tractor. I don't understand your pain.
I AM 77 AND DON'T SEE ANY REASON TO-WRESTLE,PRY,PUSH,PULL,,TRY TO LIFT AND GENERAL TYPE FIGHT WITH AN IMPLEMENT IF THERE IS A BETTER/EASIER WAY.. MY OLD 48 8N HAS ADJUSTABLE BOTH LOWER ARMS AND IS WORN AND LOOSE,,BUT STILL HARD TO HOOK UP SOMETIMES..JUST ME,,YOUR WAYS MAY DIFFER.. HAVE A GOOD DAY ANYWAYS,,
/ Implement hook up problems.. #26
Well they have quick release ends for the lift arms. Which are different lift arms you can get. John deere has some square tubing/ square inner sleeve type that work good. Also there is a quick hitch available.
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
100 gal L Double Fuel Tank (A66408)
100 gal L Double...
2011 Dodge Charger (Police), VIN # 2B3CL3CG7BH526995 (A65563)
2011 Dodge Charger...
213063 (A64276)
213063 (A64276)
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
