Implement for removing debris from soil?
/ Implement for removing debris from soil? #1
jgibbens
Hopedale, IL
Kubota BX 25D
I've heard that there is some kind of implement for removing debris from soil but haven't been able to figure out the right search term(s). My new property has a history as a dumping ground and there is a lot of broken glass/nails/??? mixed in. The soil here is mostly sand. What should I be looking for?
/ Implement for removing debris from soil? #2
If you are trying to clear trash of 2" or larger you can use attachments that are considered rock pickers such as rock buckets and some one is making a drum that rotates that separates dirt. For smaller trash you could try a soil conditioner also called a Harley rake that will rake the surface down to an inch or 2 and you can windrow the trash to pick up. Smaller trash like broken glass may be some thing that you have to pick up by hand.
/ Implement for removing debris from soil? #4
The beach cleaner is a great machine but there is a minimum horse power requirement and it needs rear hydraulics. It is also a very pricey machine.
Those beach cleaners look good for keeping the surface clean.
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A67148)
2015 ALTEC AT200...
2017 Ford F-250 Knapheide Service Truck (A64556)
2017 Ford F-250...
