IH 504 radiator help
/ IH 504 radiator help #1
Nut4trucks
Clarksville, TN
IH 504 with New Idea 504 FEL
Gentlemen,
I am running an IH504 gas tractor and the radiator started to leak between the core and the top tank. I took it to a radiator shop (in business since 1956) and they said they couldn't patch it, they could only recore it. It seems a recore is almost as expensive as a new radiator. The only problem is I can't find a new one. It is IH part #377092R92. I have scoured the internet with no luck. Does anyone no if a radiator out of another model will fit? My manual covers the 330, 340, 504 and 2504, so I assume those three are very similar. Any help would be greatly appreciated.
/ IH 504 radiator help #2
You might have to go some to find a good radiator from a tractor that vintage. The recore might be the best lin the long run!
/ IH 504 radiator help #3
I just checked my sources and I come up with no listing for radiator for #504. Ken Sweet
/ IH 504 radiator help #4
I have a '67 504. Nice tractor.
Personally, I think I'd recore it and have them check it over good when they have it apart. Most everything on a radiator of that vintage can be repaired/fixed by a good radiator shop.
Good luck.
Gentlemen,
Thank you so much for your help. Based on your input and scouring the country side, I have decided to get it re-cored. I am told it will be at least $400 dollars, I was hoping maybe to buy a new one for $600 or so. Oh well, thanks again fellas.
Tony
John Deere M665 (A62183)
John Deere M665...
JOHN DEERE 8000 WATT GENERATOR W/ GAS ENGINE (A63745)
JOHN DEERE 8000...
SET OF (20) ACE CATTLE PANELS W/ CONNECTING JOINTS (A63569)
SET OF (20) ACE...
CASE IH 3900 DISC HARROW (A63290)
CASE IH 3900 DISC...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
2016 John Deere WG48A (A62183)
2016 John Deere...
