Ideas for repairing radiator? REPAIRED!
/ Ideas for repairing radiator? REPAIRED! #21
Sandpaper and clean the area in need of repair. Apply super glue and quickly sprinkle baking soda into it.
/ Ideas for repairing radiator? REPAIRED! #23
The baking soda makes the super glue form a super hard resin. I've repaired many plastic parts with it. I've read it has been used to repair helicopter blades.
/ Ideas for repairing radiator? REPAIRED! #24
I shouldn't even ask but did you hear that from I Herd or Tha Said? Them jokers spread more BS than Farmer Brown's old bull.
/ Ideas for repairing radiator? REPAIRED! #25
I can think of two things that should NOT be repaired. Plastic radiators and helicopter blades. :)
Old school metal radiators not included but I witnessed the destruction of a $40,000 generator from a repaired radiator fail. I have seen many a metal radiator have the tanks removed and re-soldered with great success but on this one they soldered a stress crack in the tank. A new crack opened just inches from the first and the overheat protection failed to shut it down. This was on a University research building and thousands more along with years or research was lost due to the ultra low freezers that went down.
/ Ideas for repairing radiator? REPAIRED! #26
So the overheat protection failed.
/ Ideas for repairing radiator? REPAIRED! #27
That is how they fix helicopter blades. Blades are a lot bigger than most folks think.
/ Ideas for repairing radiator? REPAIRED! #28
Did they not have any overheating measures in place for a $40,000 engine designed to run unattended? I do agree repairing plastic radiators is a lost cause.
/ Ideas for repairing radiator? REPAIRED! #29
Joke all you want. It works. For $5.00 test it out u will see. There's plenty of info to back it up just Google it.
/ Ideas for repairing radiator? REPAIRED! #30
Super glue for helicopter blades???
Sure would like to see the FAA/DOT PMA approval no's!
and.....the extensive test results required.
But then it was on the 'net so it must be a true fact----------------!
/ Ideas for repairing radiator? REPAIRED! #31
The first thing you need to accept is that everything on the internet is true. Once you accept that, life will get easier, it says so on the internet.
/ Ideas for repairing radiator? REPAIRED! #32
They’re probably just filling in chips for better aerodynamics vs gluing a blade that’s broke in half back together.
/ Ideas for repairing radiator? REPAIRED! #33
Depends on the two part epoxy.... Try JB Weld.... IT will even seal fuel tanks, should be good with water....
I've used this exact J-B Weld on the front head bolt (stud) on my 1946 Willys CJ2-A to seal it from the water and to re-thread the hole. Yes, it works in water (after letting it dry hard). I torqued the head bolt nuts and it has not leaked since 2008. I have not tried the other formulas that they sell - but - this 2-Part works great !! It comes out just like cast iron !!!
/ Ideas for repairing radiator? REPAIRED! #34
bring it into a radiator shop and see if they can put a new lower tank on it - preferably a metal one.
/ Ideas for repairing radiator? REPAIRED! #36
Remind me not to get aboard the chopper.
/ Ideas for repairing radiator? REPAIRED! #38
Filling a cosmetic chip with putty isn't really a "fix"
Spending $20 on epoxy plus 4 hours pulling your rad apart in order to save $200-300 on a rad that protects your $10,000-$20,000 motor from cooking isn't really a fix either.
/ Ideas for repairing radiator? REPAIRED! #39
Engine. Yep but they have some bad axt things available now days. I'd try just to see how they do.
/ Ideas for repairing radiator? REPAIRED! #40
I am not doubting nor know any of these will work but 07wingnut's recommendation would be along the line I think makes good sense. You should install large flat washers on the machine screws (stainless) and drill the holes snug so they would remain in place as you install them using the hole from inside the radiator. Have them long enough so you could use vise grips pliers to hold the screws to tighten the nut. Would suggest a good gasket being used.
Along the concerns of another failure the biggest concern I would have is not the cracking coming back but the nipple totally breaking off. Temperature gauges normally measure the coolant temp not the engine temp so loss of coolant would allow the engine to be very hot before you noticed it.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
UNUSED RAYTREE RMH680 HYD HAMMER (A60432)
UNUSED RAYTREE...
iDrive TDS-2010H...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
