Ideas for repairing radiator? REPAIRED!
   / Ideas for repairing radiator? REPAIRED! #21
Sandpaper and clean the area in need of repair. Apply super glue and quickly sprinkle baking soda into it.
   / Ideas for repairing radiator? REPAIRED! #23
The baking soda makes the super glue form a super hard resin. I've repaired many plastic parts with it. I've read it has been used to repair helicopter blades.
   / Ideas for repairing radiator? REPAIRED! #24
I shouldn't even ask but did you hear that from I Herd or Tha Said? Them jokers spread more BS than Farmer Brown's old bull.
   / Ideas for repairing radiator? REPAIRED! #25
I can think of two things that should NOT be repaired. Plastic radiators and helicopter blades. :)
Old school metal radiators not included but I witnessed the destruction of a $40,000 generator from a repaired radiator fail. I have seen many a metal radiator have the tanks removed and re-soldered with great success but on this one they soldered a stress crack in the tank. A new crack opened just inches from the first and the overheat protection failed to shut it down. This was on a University research building and thousands more along with years or research was lost due to the ultra low freezers that went down.
   / Ideas for repairing radiator? REPAIRED! #26
So the overheat protection failed.
   / Ideas for repairing radiator? REPAIRED! #27
That is how they fix helicopter blades. Blades are a lot bigger than most folks think.
   / Ideas for repairing radiator? REPAIRED! #28
Did they not have any overheating measures in place for a $40,000 engine designed to run unattended? I do agree repairing plastic radiators is a lost cause.
   / Ideas for repairing radiator? REPAIRED! #29
Joke all you want. It works. For $5.00 test it out u will see. There's plenty of info to back it up just Google it.
   / Ideas for repairing radiator? REPAIRED! #30
Super glue for helicopter blades???
Sure would like to see the FAA/DOT PMA approval no's!
and.....the extensive test results required.
But then it was on the 'net so it must be a true fact----------------!
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
