Ideas for pulling wood posts with tractor
/ Ideas for pulling wood posts with tractor #21
I've got a homemade boom for the 3pt that works really well for pulling posts up...most posts. We've had the boom forever and I vividly remember my dad just about flipping the old 2040 over trying to pull up a railroad tie. Usually they'll pull straight up but as others have mentioned, a little knocking around can really loosen 'em up, even if they're in concrete.
/ Ideas for pulling wood posts with tractor #22
No matter how you pull the posts, the holes need to be filled immediately. Sad experience has shown me that small animals fall into empty post holes and can't get out. They can't get food or water unless it rains, then they drown.
/ Ideas for pulling wood posts with tractor #23
Great point, I covered my window wells to stop that problem, never thought about post holes. These poor critters have it hard enough without me adding to their problems.
/ Ideas for pulling wood posts with tractor #24
Although I've never tried this, nor know anyone who has.....would using a pressure washer to drill into the soil around the post to loosen them be a help? I have....put in t post that way, when it was August in a drought and the soil was like concrete. Literally cut a hole with the pressure washer, then the t post went right in.
Quick update:
I spoke with the the guy today. He said this is not a pond, but an area where a pool used to sit. He said it is dried up and packed sand. He said half the posts are wood in concrete and half are aluminum posts in concrete. I will be attempting this task this weekend. Let me know if you have any last minute ideas. Thank you in advance,
Sent from my iPad using TractorByNet
/ Ideas for pulling wood posts with tractor #26
If you have a 4 in 1 bucket very easy. Open bucket drop to base of post clamp and pull up and out. It is very easy to break 4 by 4. 6 by 6 are more forgiving . They do come up with concrete attached and labor to remove it can easily exceed cost of post.
/ Ideas for pulling wood posts with tractor #27
I just wrap a chain around the posts I want to pull and hook it to a grab hook on my pallet fork frame and boom up. If it doesn't pop right up, a little back and forth on the HST pedal and then they usually come right out.
/ Ideas for pulling wood posts with tractor #28
I would try the fel first. If that did not work, I would get a truck tire rim. Run a chain from low on the post over the rim and to the draw bar on the tractor. Pull. The rim converts the forward motion of the tractor to a vertical pull on the post.
The truck rim method is the way my Grandpa did it, it generates a lot of upward force.
/ Ideas for pulling wood posts with tractor #29
I once pulled a dozen 4 x 4 posts that were 4' deep using the hydraulics that raised my snowplow blade on my plow truck.
The front tires kinda squatted but all the posts did come out fairly easily, even those that had some concrete bedding.
With my FEL I have curled the bucket with the heal on the ground as that provides more leverage. In all cases I nudge the post a couple of times with the FEL to loosen the grip. Early spring with wet soil shortly after spring thaw is the best time.
Never thought of a plow truck (I don't have one but that's a good idea).
If I could manage to keep the chain taught and lift up, I like the heel of the bucket idea too.
My only fear if the front loader, is balance of the tractor. I am afraid of lift the rear end without enough ballast.
I think I may still try hooking up to my 3pt. Anyone know how much the bar between the extended links can take before bending? Breaking? I was thinking of backing to the post, wrapping a chain around the post and the bar then lifting. Any reason not to do this?
/ Ideas for pulling wood posts with tractor #31
Thanks for all the good info.
/ Ideas for pulling wood posts with tractor #33
If you are using the FEL try hooking the chain short so your loader will be lower and more powerful.
/ Ideas for pulling wood posts with tractor #34
Some videos:
Removing Posts - YouTube
This video is the way to do it. I wouldn't worry about bending the 3 PH drawbar, they are pretty strong and will hold as much as your tractor hydraulic will put out. You can also use the drawbar to push and pull on the post a bit to loosen it up if it doesn't come out at first pull.
One thing about the video that needs to be done differently is at the end when the post fell over might be a little dangerous if the post is tall. You may want to pull it most of the way out but leave it in the ground so it remains standing, then use the FEL to finish lifting it out, that way you can chain it up higher so it doesn't fall on the tractor (or you)
/ Ideas for pulling wood posts with tractor #35
As long as he keeps the drawbar vertical he won't bend it when he lifts on them. If he pushes against the post with the drawbar vertical he will bend it.
/ Ideas for pulling wood posts with tractor #36
FYI if you have broken off T posts (that rust at the ground level) or someone use angle iron as posts, you can clamp a set of vise grips on the top then wrap the chain around the post, the vise grips on the top will keep the chain from slipping off. If that doesnt work, you can use the vise grip trick with a lifting strap that will sinch around the steel better than a chain will. Wood posts the chain will dig in nicely and bite else you can use a brush grubber.
We had used a chain for years and it worked ok... then I had santa claus finnaly bring me one of those and oh what a difference it makes! its worth the $80!
FYI if you have broken off T posts (that rust at the ground level) or someone use angle iron as posts, you can clamp a set of vise grips on the top then wrap the chain around the post, the vise grips on the top will keep the chain from slipping off. If that doesnt work, you can use the vise grip trick with a lifting strap that will sinch around the steel better than a chain will. Wood posts the chain will dig in nicely and bite else you can use a brush grubber. We had used a chain for years and it worked ok... then I had santa claus finnaly bring me one of those and oh what a difference it makes! its worth the $80!
I saw the cool vice trick on YouTube... Looked like a good idea
/ Ideas for pulling wood posts with tractor #38
That isn't likely with the tractor he has (28 HP @PTO) unless he rams the post with it. I have used them with much larger tractors pushing and pulling and never bent one, but of course one had to use good judgment with any device. An anvil can be broken with enough force. If excess force is applied, he would stand a better chance of bending his 3 PH lift arms or some other component of the 3 PH before bending that drawbar.
/ Ideas for pulling wood posts with tractor #39
I bent one with my tractor that is not much bigger than Kens. I was pulling small trees. I did not jerk on it. If it would have stayed with the holes up I would have not bent it.
/ Ideas for pulling wood posts with tractor #40
This is similar to how we put in or remove dock piles and jettys on the sandy shores of Lake Huron with a 5hp, 2" portable pump & 1 1/2" hoses to reach from shore or raft. With a pipe lashed to board/pole/post flush to the end, 2x10s or posts go in or out by hand. (easy to balance when standing waist deep, too ;)) This ought to work as well above the waterline as below, and I'd think a PW would best a garden hose (or PHD) when pulling a bunch, so IMO a good call! :thumbsup:
btw: I've been a Brush-Grubber guy for years, have two small ones, and have 'rocked' till my R wheels came off the ground working 'em with the FEL. With trees OR posts, the easy part is nudging them around with the bucket to loosen, first. Now, if I wasn't so lazy I'd turn the tractor around, use the 3PH to lift, and make the whole job easier. :duh:
2025 Swict 84in Bucket Skid Steer Attachment (A66734)
2025 Swict 84in...
2023 JCB 90Z-2 T4 Midi Excavator (A66734)
2023 JCB 90Z-2 T4...
2002 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2002 FORD F150...
2016 JAY FLIGHT BY JAYCO BUMPER PULL CAMPER (A67714)
2016 JAY FLIGHT BY...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
CASE SV208 SMOOTH DRM ROLLER (A67714)
CASE SV208 SMOOTH...
