I want to buy a yanmar, need help on HP
   / I want to buy a yanmar, need help on HP #11
I don't have a double bottom plow but I do have a 16x12 disc. I pulled it with a YM2500 for a while. I put about 100 extra lbs on the disc and the 2500 was really loaded. It also bounced me to death even after I put an air suspension seat on it. I upgraded to a 3110D and it pulls it like a dream.Plenty of power and a much smoother ride. The 3000 and 3110 have much larger tires, but basicly the same frame except for the engine. The bigger tires and the 5 or 6 extra hp really make a difference. As far as being able to do work, like grading, discing, mowing, and box blading, my 3110D is twice the tractor that my 2500 is. During the post Katrina cleanup, I was able to move logs and stumps that my 2500 would not even budge. The only disadvantage that I have noticed is it is harder to handle in close quarters. If all you are going to do is straight ahead work the standard shift will be fine. If you think you are going to be working a box blade with a lot of backing and going forward I would definitely spring for the power shift models. I took the D model somewhat under protest but now I am really glad I did. Having 4 wheel drive has come in quite handy many times. It also helps it steer better on soft or freshly plowed ground.
Revision:
After looking at your original post again and seeing you using a tiller and a bushhog I say the 3110D. The 3110D will also handle a 6ft bushog. One other thing; if you have any gates to drive through measure them first.
   / I want to buy a yanmar, need help on HP #12
I think you will get somewhat varying suggestions here because our tractors are several years old and most have large differences in power due to years of use.
On mine 2610D, when I first got it I would have said NO it will not do what you typed you wanted to do with the tractor. But now after a rebuilt head and motor I would say YES it will do what you need.
Mine has a turbo too so my power may be a little more than a standard rebuild 2610D but I believe even without a turbo, a fresh 2610D will do the job. I strongly suggest a "D" version.
   / I want to buy a yanmar, need help on HP #13
tony123 said:
I have a YMG2000D with 23hp (+/-) Will it pull a double bottom plow through unworked dirt?
It really depends both on set up (ie weight and such), but mostly on the type of soil. Montana gumbo--maybe not, but alot of other places, yes. I have seen some soil that when dry you would have a hard time pulling a single shank ripper through it with a D8 Cat. Most soil is not like that.
Mike
Well thanks to everyone. I was thinking a ym2500 would do it but I may need to go up a little. So I remain confused but still have my money. Anyone know where there are any deals out there or any to stay away from??? As this is my first tractor I am afraid of making a big mistake.....to small to big. Maybe I should stay with the 2500 & go with a single plow. Any thoughts anyone? Thanks again. BB
   / I want to buy a yanmar, need help on HP #15
There are a number of dealers that frequent this forum. We could recommend a dealer if we knew where you are. If you could update your profile with some more info. The dealers will be in a good position to tell you what will accomplish the tasks that you have for the tractor to do.
Mike
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
