I Want to Build The Ultimate Root rake/Grapple
   / I Want to Build The Ultimate Root rake/Grapple #11
JBA, What type of steel did you use for your tines?
   / I Want to Build The Ultimate Root rake/Grapple #12
I'm just using mild steel. I debated about what I should use on this and decided for what I wanted to do it would be sufficient. The inner tines are 1/2" thick and the outer tines are 5/8". I also made my tines broader more quickly in order to add strength. I figured the worst case scenario would be that I have to add some bracing but I think this will suffice.
   / I Want to Build The Ultimate Root rake/Grapple #13
Unless you are using it for construction demolition, there is no reason to use more than mild steel. My grapple is made of 3/8ths mild steel and it has not shown any wear at all other than paint removal after about 60 hours of work with brush/stumps etc.
   / I Want to Build The Ultimate Root rake/Grapple #14
MrJimi, if you don't mind me asking, what are the uses for this grapple? Brush clearing, trees, removing roots from your sand? It seems to me that there are 2 basic designs, and that while each type will do ag & demo type work, the 2 different designs are intended for the work of its specific design. In other words a demo grapple works better at demo than at ag type work and vice- versa.
Just something else to consider.:)
Something else for everybody to keep in mind, is just because something works great for you does not mean that it is the same for the other guy. We all have different tractors, different uses, different circumstances to work with.
   / I Want to Build The Ultimate Root rake/Grapple #15
MtnView,
I agree completely. The biggest reason I chose to build the style I am, is because of the back raking ability that it has and the visibility that it offers. I plan to use it for building some rock walls and need to be able to see through it.
jba
   / I Want to Build The Ultimate Root rake/Grapple #16
jba3520 said:
I too was interested in the SkidSteerSolutions Root Grapple and I am just about to start to weld mine together. In fact, I based the design off the picture you posted. Mine is 60" wide and about 420 lbs. but could easily be scaled up or down. I had all of the pieces laser cut and I'm just waiting on the last pieces from the machine shop. I purchased the cylinders online and only have the hydraulic hoses and fittings left to buy. I figure I'll have about $1000 into it when I'm done.
I will try and post some pics but I have never done that before so I hope they work.
You guys with skills make me sick.... with envy that is.
Check for a PM.
jb
   / I Want to Build The Ultimate Root rake/Grapple #17
I agree. The only way I can match these skills is by reading out the digits of my credit card over the phone.:(
   / I Want to Build The Ultimate Root rake/Grapple #18
Hey, no skills here, just a whole lot of reading and observing others... and then a lot of trial by fire! My dad always said those who never fail, are those who never try. So I keep trying.
Blades
I plan on using it mainly for small brush and roots and grappling the brush after wards , like in the video the top can be used for backdraging like a rake in reverse, I have lots of stuff to do right now but I have a great idea from J_J , his is nice and mine will be close. His design is simple and strong and I can work off of that.
Thanks
Jim:)
   / I Want to Build The Ultimate Root rake/Grapple #20
This is the grapple I built. I run it on my JD 4310. When we bought the tractor I wanted to be able to use the tractor to pick up debris (from wind storms and old junk on the property) and pull blackberry bushes and other vegetation out of the ground. It has also worked great for picking up logs and having two people run chainsaws to chop pieces off each end.
The grapple weighs about 250lbs, i think. It is 54" wide with 7 tines approximately 9" apart, the top closing part is 36" wide with 7 tines about 5" apart. The tines are 24" long on the bottom. The holes were cut to reduce weight. It increased the price of cutting, but I wanted the weight reduction.
I used 5/16" T-1 on the tines, and 1/4" for the backing and structure. Used 2" square tubing to build it off.
I had the T-1 pieces plasma cut at a local metal supplier. They didn't have the T-1 in stock so I had to purchase the whole piece, I kept the scrap. :)
I dual shield welded it, this allowed me to get very good penetration on the weld joints. I pre-heated the metal before I welded it. After it was done, I then hardfaced all the lower tines.
I have it setup for quick release off the front. I didn't know how to plumb the hydraulics so I had the dealer do the hydraulics for me. Now, I could do it the next time.
I bent the outside tine prying a rock out of the ground, so I cut a 1/4" wall 1" pipe in half and welded that to the outside tines.
If you want more information, just let me know.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Brent 1082 Auger Wagon (A59814)
Brent 1082 Auger...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2024 Spartan SRT-XD Zero Turn Mower (A59814)
2024 Spartan...
