I think my tail wheel is too big
   / I think my tail wheel is too big #31
:laughing::laughing:
And even if it is a "different wheel" and is "supposed" to be bent like that (which I doubt), the obvious solution is to heat up the shaft, and bend it so it wont rub. Problem solved very simply. Who cares what the wheel is off of or wether it is "actually" bent or not. Just modify it to work. Its not rocket science
....and yes again. :)
   / I think my tail wheel is too big #32
Try lifting the implement when backing up then lower it and continue in forward.
Have to agree with everyone else, that is not the correct tail wheel assembly. It should be vertical.
   / I think my tail wheel is too big #33
Or you could do like I did when I bent one of mine,turn the wheel around and back into anouther tree. Didnt have to take it off and heat it. REDNECK way.
   / I think my tail wheel is too big #34
This is the rear wheel on my Behlen cutter. I have the rear of the deck up on a log for winter storage.
   / I think my tail wheel is too big #35
What winter:laughing:
   / I think my tail wheel is too big #36
As I stated before the TOP of the forks should be level as in the picture in post #34 the forks should be canted. In the ops original photo the top of the forks are at an angle,therefore BENT.
   / I think my tail wheel is too big #37
Take a harder look. Those forks use a cheaper fab method relying on some bend in the neck above the top of the [straight] forks to give the caster angle. he just needs to unbend the neck a little. A couple weld beads on the back side while stressing it in that direction oughta do it ... and leave it stronger.
larry
   / I think my tail wheel is too big #38
easy to see its bent
   / I think my tail wheel is too big #39
   / I think my tail wheel is too big #40
You've proven it's bent. Look at the picture you posted. The SHAFT is shown straight. Look at the OP's picture --> his shaft is bent.
No, I haven't proven anything...that's a picture of a Land Pride cutter. We have no idea who built the OP's cutter and the design might be different.
You're assuming all cutters are the same...they're not...but every one I've seen had some cant to the tailwheel.
TRAILER AXLE (A51244)
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
