I hate gutters
/ I hate gutters #1
Bo McCarty
Got leaky gutters? I do.... Not sure if the water running off the roof is just missing, but it seems a lot of leaking for it to be a seam leaking.
/ I hate gutters
Lowe's aluminum....nothing special. I sealed the joints, I still don't think that's the problem.... The bottoms of 2 sections are wet and drip from one end to the other.
/ I hate gutters #4
Afternoon Bo,
Well it sounds like youve been up there to seal and inspect. I was just gonna add that if the downspout is plugged up and you have a lot of water in the gutter that it could actually leak out of the point where the spike passes through the gutter into the roof joist.
/ I hate gutters #5
Hi Bo. Perhaps you have a problem of your roofing not being sealed to the flashing of the gutter. I have that problem with some of the gutters on our metal roofing. The runoff comes down the metal roof, sort of doubles back a little and runs underneath the gutter flashing, wetting the bottom side.
Mike
/ I hate gutters #6
Post some pics.
Bob
/ I hate gutters #7
Timber excuse me , but who in their right mind would have WOOD gutters?
/ I hate gutters #8
Those gutters you get from the box stores are a great value, but they are very, very dificult to get to seal. The almost always leak when you use the sealant they provide with them. I've found that a really good roofing cauld spread over the seams and pushed into the seams on the inside of the gutter will solve your leaking problems.
Make sure the gutters are clean and dry. Use your fingers to really work it into the fitting that holds them together, then spread it out over the fitting. I like to use plenty of sealant so I don't have to go back and do it again. Make sure to go all the way up the sides too!!!
As for sealants, there is a black roofers caulking stuff that is very good. It's pricey, but it takes the weather better than most anything else. Next choice is a top dollar silicone. Window and door type stuff. Make sure it's for outdoor use!!
After your done and it's had a day to dry, use the hose to test it. Just let it run into your gutters and see what happens.
Good luck,
Eddie
/ I hate gutters #9
It sounds like an installation problem to me. Gutters shouldn't hold water long enough to have leaking be a problem. You might check to see if you've got the guttering pitched right to flow water and enough downspouts.
My son in law installs seamless gutter for my adopted son. They have a product they call "guttermans friend" that is the meanest stuff the far side of Gorilla Glue. If you get it on you it's a wear off clean up. But it will seal and it's self leveling.
/ I hate gutters #10
In New England most houses have wooden gutters; the real good ones are copper lined. My 2nd business I started was in historic building restoration. I specialized in 17 & 18 century. I did this for 10 before I sold the company. All homes of this period have wooden gutters and copper downspouts. Many of the down spouts were replaced with galvanize over time. The use of a wooden gutter is to make the gutter invisible and make it part of the trimming of the home. As a rule from top to bottom it goes like this Gutter, molding, soffett, fascia, crown molding, dental molding or rope molding or both. Then your Queen Ann Victorian homes have even more and the ginger bread can consist of all kinds of moldings and coins. A lot of times the copper downspouts are hidden behind the coins. I am sure this means very little to you since you didn't know what a wooden gutter was. This type of construction is always found in your Victorian and Federal style homes as well as all your churches. It is still used today on any home that has a sculpted trim and multiple color schemes because wood is still the greatest material to build style into a home.
/ I hate gutters #11
My 1st recommendation without seeing your home and problem would be to add or replace the drip edge. Now do this in the sun on a warm day when you can lift the tabs (Gently) so not to crack them. There is a special flat bar you can buy anywhere to sneak the roofing nails out. You may or may not have to release the gutter hangers to let the drip edge slip over the gutter edge. It depends on how high on the fascia board you set the gutter. Also be sure your pitch is correct so the water flows quick enough that it doesn't bag the gutter out with the wt. of the water. When you go to nail in the new drip edge because you sneaking under your roof tabs, predrill the nail holes in the aluminum so you have less swings with a hammer and less chance to hit the tab
/ I hate gutters
As always lots of great information. I hope to have this darn thing fixed this weekend, or by next weeks rain (we're clear for a few days).
Oh, the gutters only leak when it's raining! ha.
/ I hate gutters #13
I was watching some This Old House shows a few years ago and that was the first I had seem wood gutters. I thought it was nuts until I saw them line them with the copper and all the associated trim work. Man, that was a work of art. Very nice and it will last another hundred years. Good stuff. :)
/ I hate gutters #14
I had some gutter leak problems last year and I tried a 2 part epoxy that can be applied under water. It's called Mr. Sticky's. My gutters are now leak free. :) Great stuff that I have found other uses for. www.mrstickys.com
/ I hate gutters #15
Wooden gutters are the best, They outlive almost any other material as long as the are taken care of. The need to be oiled every fall or every other. There are some new composite materials out there but they break down in the UV and they never hold paint very well. Most Victorians an in 7 to 9 colors Homes out of the early 1800 are usually in Tory colors. That is all white,or Yellow body white trim. Most have white chimneys with black caps. and all shutters are green. There are a lot of homes that are in the historic districts that have to be done in these colors or you are fined by the town. The same rule applies to Xmas lighting. A lot of towns are white lights only or the town will fine you. My company was a Paint removal operation for the most part but that is just part of what I did. Lead poison is the hazard with that trade
/ I hate gutters #16
Bo McCarty, the most common problem with gutters leaking after replacement is the drip edge. When you have new gutters installed on your home the old ones are torn down and the new ones are hung up. This is where the drip edge comes in play. When the new gutters are installed the high end (furthest from the down spout) is placed over the drip edge not under it like it should be and fastened to the fascia. The rainwater now drips behind the gutter instead of in it. To fix this I purchase some jumbo drip edge (hangs down further) not standard and slip it under the first shingle. Now the drip edge is inside my gutters. I only do this in areas where my gutters are installed over the existing drip edge. I don’t even need to nail it or caulk it to stay in place.
/ I hate gutters #17
Mike
I have the inexpensive vinyl guttering from Home Depot on my place.
I had to use the plastic drip edging since the shingle overhang is too short.
Without the edging water would get between the rear of the gutter and the fascia board.
Had a few days of rain this week. No leaks between the vinyl sections (yet).
I guess I had better start looking for some good gutter adhesive just in case.
/ I hate gutters
I think I have found the problems. I started fixing the problems Saturday and should have it taken care of this evening.
Problem 1. My chalk line must have had a wiggle. The gutter was on the line, but after eyeballing, then sticking a level on the gutter, well, lets just say water won't flow uphill. Just happens that's where a joint was doing a drip drip drip.
Problem 2. Some of the water was running behind the gutter on one section (yep, the leaky one).
Thanks for all the help.
/ I hate gutters #19
We replaced some gutters high up (3 stories) on the house plus a short run right in front that kept plugging some with leaves. Replaced with a seamless guttering with a top on it that is guaranteed for life not to plug up. It was impossible for us to service those gutters and very difficult to find anyone to do it.
In Baton Rouge, most houses do not have gutters. Found out why when we converted a porch to a breakfast room and felt we needed a gutter on its back wall to keep rain from spattering off the deck onto the outside wall. That one downspout kept plugging up with stuff growing up it about every 3-6 months.
Ralph
/ I hate gutters #20
Here in Douglas County (Colorado) we are bulding a new house.
The local codes requires that ALL buildings have gutters.
Our house under construction doesn't have them yet, and in the two years I've been working on it, we've had record setting downpours and snow.
Surrounding houses lose their gutters every 2-3 years when there is 4-5 feet or more of snow in a day by the weight tearing them off if melting is fast enough to release all the snow at once.
Might be a good place to start a gutter installation business! :->
Mark H.
2003 (INOPERABLE) CHEVROLET C7500 (A67714)
2003 (INOPERABLE)...
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
2016 Nissan Titan XD Crew Cab Pickup Truck (A66736)
2016 Nissan Titan...
Shop Cart (A68134)
Shop Cart (A68134)
2005 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2005 INTERNATIONAL...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
