How do I protect rain gutters from ice damage?
/ How do I protect rain gutters from ice damage?
Here is a picture of the gutter, damage, and profile of the metal roof.
The eave extends about 3 feet past the metal building, and I believe this is a contributing factor. So right now I am leaning toward heat tape along the top of the roof above the eave, and inside the gutter as well.
/ How do I protect rain gutters from ice damage? #42
I just ordered a set of heated steps pads , 10” x 30” plus a 3’ x 5’ heat mat for my front steps. Sick and tired of shoveling steps.
I put some electric heat mats (ThermoSoft) in my walkway and kitchen step this summer when we replaced the concrete.
Turned them on last night and this morning for a little bit. Had some snow that had turned to ice this morning after having the mats on for 2 hours I could take a shovel and scoop up the ice and get rid of it.
I have (2) 24" by 24 ft and (2) 24" by 5 feet with my electric at almost $0.20 KWH when they are all turned on it will be costing me about $1.20 per hour.
So I'll still be removing most of the snow, but the house eve drips on the concrete as the roof snow melts when the water hits the concrete it's instant ice. This is the North East side of the house so it gets almost no sunlight on the concrete in the winter.
We just put new siding, soffits and fasia on the house and it isn't set good for gutters which would also have to have heat to prevent completely freezing full including the down spout.
Previously we just didn't use the kitchen walk door in the winter because the ice made it almost impassable much of the time.
/ How do I protect rain gutters from ice damage? #43
It's a shame the gutters couldn't be lowered 6 inches and then adequate heat reasonably applied to keep them from filling with ice.
I will look to see if that is possible. But if ice is breaking free and sliding down, it seems it would still catch the gutter?
/ How do I protect rain gutters from ice damage? #45
Just put cheap ice guards on, no need for heat
/ How do I protect rain gutters from ice damage? #46
It extends about 3 feet past the exterior wall, 4 in 12 pitch. The building sales person talked me into that configuration to make it more fit in with a "high end residential rural area" and I agree. I regret that decision to this day, for this issue and more.
I'm talking about the metal roofing itself. It should extend past your eaves, over the gutters 1-3 inches. If it's closer to 3 inches, you may be able to lower the gutters enough for the snow and ice to go over top of them. If you lay a straight edge on the roof, over the gutters, you want to outside edge of the gutters to be lower the straight edge, ideally 1-1.5 in. lower. Doing this, combined with the metal roofing being out about an inch in from the outer edge of the gutter allows the sliding snow to shoot out over the gutter rather than getting hung up and ripping it off. Is this building insulated? Heated? In almost all cases, the more overhang you have, the better. It helps to better protect the whole building, all the way down to the foundation.
My building is properly engineered for snow load for the area. And after LAST year, I know I am safe. We have an unbelievable winter that will likely never recur in my lifetime. 😀
I was talking about bigtiller's building, not yours. He/she mentioned that a Morton building salesman said they roof should be metal to prevent snow build up.
/ How do I protect rain gutters from ice damage? #47
The ice doesn't just go off the edge of the roof and immediately drop straight down. It sort of curves as it slides off the edge of the roof. The idea is to get the gutter on the inside of that curve, like a surfer inside a big wave.
/ How do I protect rain gutters from ice damage? #48
They put ice guards on my new carriage barn. They all tore off the first year and left 50 holes in roof.
ill never use those again.
It is a 60x60 metal building, 4:12 roof pitch with about 3 ft overhang at the eaves, 6" insulation on interior walls and ceiling, and heated .... sort of. It is not heated to comfort standards but has a Reznor 250k btu propane heater that prevents the interior from going below the mid-30's to prevent internal freezing. 40F temp on the inside is not uncommon at all, often warmer during the day.
In my climate, it is frequently below freezing at night, and frequently above freezing in the day. During the day there is significant UV exposure leading to rapid snow melt. So lots of freeze/thaw cycles.
/ How do I protect rain gutters from ice damage? #50
That'd be caused by incorrect installation or an incorrect product for the application. Doesn't mean all ice guards are at fault.
/ How do I protect rain gutters from ice damage? #51
My thoughts exactly. All of us in the north have them, never a problem. Sounds like poor construction
/ How do I protect rain gutters from ice damage? #52
Nope, ive seen them happen on lots of buildings up here. Problem happens when we get large ice buildups on roofs. Mine had nearly 3’ of ice trapped behind the dams.
i was worried ice dams were going to cause my building to collapse.
now, i just let everything shed off and move mess with tractor. At least everything now sheds instead of just continuing to build up.
/ How do I protect rain gutters from ice damage? #53
There are lots of buildings up here (I'm a contractor in North Idaho) that are built poorly or incorrectly for the region. Wind and snow load, roof pitch, roof size, building insulation level, building orientation, heat leakage etc. all factor in when picking the right product. Plenty of folks don't consider all of the factors and pick the wrong product or install it incorrectly. Plenty of folks in this region also rely on steep, metal clad roofs and poor insulation to keep their building that isn't constructed for the snow load from collapsing.
All that said, there's nothing wrong with letting the snow slide off the roof if it's not gonna get in the way too much. The snow on my place slides off and builds up to the point where I can step from the pile right onto the eave of the roof on my lean-to. Helps keep the wind out of there. (y)
/ How do I protect rain gutters from ice damage? #54
I have seen even ladder style snow stops on commercial metal buildings rip right off. I wouldnt try to stop the snow. I would try to lower the gutter enough that it wont get hit by sliding snow/ice.
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
CAT Chassis Only (A59076)
CAT Chassis Only...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2016 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2016 Peterbilt 579...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
