- Joined
- Aug 31, 2001
- Messages
- 66,020
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
e?
Moss, even if empty, once filled, a solar pump would keep it topped off indefinatly whenever the sun is out.
RD
What I'm getting at is that pump may not be big enough to overcome the evaporation rate, depending on the size of your pond, of course. As I mentioned, we have a 24' pool. It's surface area is approximately 450 sq. ft. If I leave the cover off, I can lose 1/8 inch a day to evaporation. That's approximately 60 cubic feet of water, or about 450 gallons. An 1100 gallon per day pump would only be able to keep up an approximately 1100 sq. ft. pond at the evaporation rate I experience. That's about a 38' diameter pond. I just don't want to see you buy a pump that is undersized for your needs, that's all.
Best of luck with your project.
