hydrostatic trans fluid change
/ hydrostatic trans fluid change #1
lexus114
Bethlehem Twsp. PA
06 LT-1045 LE (v-twin)
Is it very hard to change the trans fluid in my LT-1045?
/ hydrostatic trans fluid change #2
Yes, sort of. It's a sealed unit that's not meant to have the fluid changed. But you can do so by removing the tranny from the tractor and turning it upside down. I believe it drains out a breather vent or something. You refill through the same hole.
/ hydrostatic trans fluid change #4
If you just want to do it as a preventative maintenance measure, I'd just do sucessive suck-outs and refills of the exansion tank. Without a tank, as said, you pretty much have to remove and invert the unit. Unless you want to flip the whole tractor over or drill/tap a drain hole! Here's your trans: Hydro-Gear ? LT Series
Joel
The old lubed for life deal huh? Well,thanks for all of the input guy`s.
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
