Hydraulic Fluid Change
/ Hydraulic Fluid Change #1
1620compact
Ohio
Ford 1620
Newbie Just got a 1992 ford 1620 with the HST. Want to change the hydraulic fluid. Do I put the 3pt all the way UP or DOWN? Do I fill the filters before putting them on? Any precautions I should take to prevent air in system? Found out the fluid hasn’t been changed in at least 12yrs. Thanks in advance
/ Hydraulic Fluid Change #2
Down if you wish to worry about it. Will make a minimal difference in the amount of fluid.
Just be aware that after draining and refilling some machines are a bit of a pain getting circulation established again. It may be worth while to loosen or remove the main line out of the hydraulic pump to allow air to escape.
/ Hydraulic Fluid Change #3
I just did mine yesterday and didn’t worry about the three point or filling the filter ahead of time. I started it up and let it run a minute, moved the three point up and down a couple of times, then backed up. There was a slight glitch backing up then it was fine.
