Hydro source for adding rear remotes on L4310 HST no FEL
   / Hydro source for adding rear remotes on L4310 HST no FEL
Here is a pic of the front hydro block. The oil is from when the engine oil plug fell out and the fan blew it all under the undercarriage. Long story on another thread. Engine is being replaced, turns out that engines like being lubricated...
My question now thanks to countrybumpkin is where the drain from the spool goes. I am guessing the port indicated because it is where the pressure relief flows.
   / Hydro source for adding rear remotes on L4310 HST no FEL #12
Yes I just looked in the book and you are correct on the hook-up. I sent you one Pm and will send the rest of the details in a little while for that valve I have.
Ok thanks. I will share it with the other guys at church who are also invested in this project.
   / Hydro source for adding rear remotes on L4310 HST no FEL #14
I sent you the rest of the specs on the valve.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
7ft Workbench (A57454)
Hercules Gun Cabinet Holds 40 Guns (A57454)
Hercules Gun...
Towable Tank (A59228)
