Hydraulics
/ Hydraulics #1
Fornshell
JD2240
I have a JD 2240 , Trying to adjust 3 point hitch. Took out 1/2 drive plug by selective control lever. Adjustment screw inside there won't turn, anybody know why this wouldn't turn. Appreciate any answers.
/ Hydraulics #2
What on the 3 ph are you trying to adjust? And why do you think that "screw" is the adjustment?
Do you get that from the service tech manual, or something else?
/ Hydraulics
The 3 point hitch raises by itself slowly as I am moving along bush hogging. Manual says that is a adjustment for the arms.
/ Hydraulics #4
When 3 pt hitch raises on it's own does control lever stay where it was last set or does 3pt control handle move rearward? I'll bet control handle moves rearward due to worn friction washers that need more friction/
/ Hydraulics
Lever moves rearward as arms go up.
/ Hydraulics
I'll try some new friction disc and let you know how it does thanks.
/ Hydraulics #7
Does this model have a flow control knob?
/ Hydraulics
Not that I know of.
/ Hydraulics #9
Yes all JD utility tractors with similar design built between '65-'92 has rate of drop[ screw under seat that can limit how fast 3 pt hitch lowers. But IMHO R-O-D screw isn't creating Fornshell's tractors problem.
/ Hydraulics #10
Simpler than R&R friction disks why not increase tension on friction disk by adding a shim washer to determine if that will solve your tractors 3 pt control problem?
/ Hydraulics
TX Jim why is there a red eye by my post. You have always been very helpful just wondering about the red eye.
/ Hydraulics #13
It's not because you are posting late at night. I think it is there to tell you that you are watching the thread.
Eric
2007 International Flatbed Dump (A62613)
2007 International...
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
John Deere 4040 Tractor (A64047)
John Deere 4040...
Hutchinson 8 x 32 Truck Auger (A66408)
Hutchinson 8 x 32...
Skid Steer Post Auger (A65640)
Skid Steer Post...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
