Hydraulics
/ Hydraulics #1
Fornshell
JD2240
I have a JD 2240 , Trying to adjust 3 point hitch. Took out 1/2 drive plug by selective control lever. Adjustment screw inside there won't turn, anybody know why this wouldn't turn. Appreciate any answers.
/ Hydraulics #2
What on the 3 ph are you trying to adjust? And why do you think that "screw" is the adjustment?
Do you get that from the service tech manual, or something else?
/ Hydraulics
The 3 point hitch raises by itself slowly as I am moving along bush hogging. Manual says that is a adjustment for the arms.
/ Hydraulics #4
When 3 pt hitch raises on it's own does control lever stay where it was last set or does 3pt control handle move rearward? I'll bet control handle moves rearward due to worn friction washers that need more friction/
/ Hydraulics
Lever moves rearward as arms go up.
/ Hydraulics
I'll try some new friction disc and let you know how it does thanks.
/ Hydraulics #7
Does this model have a flow control knob?
/ Hydraulics
Not that I know of.
/ Hydraulics #9
Yes all JD utility tractors with similar design built between '65-'92 has rate of drop[ screw under seat that can limit how fast 3 pt hitch lowers. But IMHO R-O-D screw isn't creating Fornshell's tractors problem.
/ Hydraulics #10
Simpler than R&R friction disks why not increase tension on friction disk by adding a shim washer to determine if that will solve your tractors 3 pt control problem?
/ Hydraulics
TX Jim why is there a red eye by my post. You have always been very helpful just wondering about the red eye.
/ Hydraulics #13
It's not because you are posting late at night. I think it is there to tell you that you are watching the thread.
Eric
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
2013 S/A Enclosed Trailer 14ft (A61569)
2013 S/A Enclosed...
2018 Ford Taurus Sedan (A61569)
2018 Ford Taurus...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
