Hydraulics
/ Hydraulics #1
Mcfclz
Bristol ct
Kubotab7100
I have a belt driven hydraulic pump on a case 442 with a FEL when ever I engage the value the pump squeals & motor bogs down. What is causing this & how could I correct the problem!! Your suggestions!
/ Hydraulics #2
Is there a pressure relief valve somewhere in the hydraulics?
It sounds like the pump is stalling due to low or dead headed flow.
If you ask a moderator to move this post to the the Hydraulics section in General Forums, or just post again there, you will get better and more help.
http://www.tractorbynet.com/forums/hydraulics/
/ Hydraulics #3
What is attached to the work ports on the valve?
If you are at the end of cyl travel, the relief will activate.
If a hyd motor is fully loaded, the relief will go off.
You may have a QD loose and can not pass the fluid to where it supposed to go.
If you have a cyl on the work ports, is the cyl moving.
/ Hydraulics
Work ports have cly connected, cly move very slowly when value is engaged
/ Hydraulics
I have a chief directional 4way value 3 pos. tandem center
/ Hydraulics #6
Speed of operation is based on pump GPM , so if you pull the lever back, what happens?
/ Hydraulics
I have a concentric gear pump 4-8 GPM driven by 18 hp vanguard
/ Hydraulics
When lever is engaged pump squeals & motor bogs & cly move slowly
/ Hydraulics #9
You might put a hyd gauge in the valve and check out the pressure.
Is the cyl connected to anything and is it binding/bent, etc..
/ Hydraulics
Clys are connected toFEL bucket & bucket frame
/ Hydraulics #11
Remove the cyl hoses and place in a bucket and then operate the lever and see if fluid flows and the relief acrivates
/ Hydraulics #12
What is the rest of the story, did you put it on, did it ever work right?
Is it like this one from Kwik-Way?
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
2011 WESTERN STAR 4900SA (INOPERABLE) (A67714)
2011 WESTERN STAR...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2017 CATERPILLAR...
John Deere 6200 Tractor (A64047)
John Deere 6200...
