Hydraulics
/ Hydraulics #1
Mcfclz
Bristol ct
Kubotab7100
I have a belt driven hydraulic pump on a case 442 with a FEL when ever I engage the value the pump squeals & motor bogs down. What is causing this & how could I correct the problem!! Your suggestions!
/ Hydraulics #2
Is there a pressure relief valve somewhere in the hydraulics?
It sounds like the pump is stalling due to low or dead headed flow.
If you ask a moderator to move this post to the the Hydraulics section in General Forums, or just post again there, you will get better and more help.
http://www.tractorbynet.com/forums/hydraulics/
/ Hydraulics #3
What is attached to the work ports on the valve?
If you are at the end of cyl travel, the relief will activate.
If a hyd motor is fully loaded, the relief will go off.
You may have a QD loose and can not pass the fluid to where it supposed to go.
If you have a cyl on the work ports, is the cyl moving.
/ Hydraulics
Work ports have cly connected, cly move very slowly when value is engaged
/ Hydraulics
I have a chief directional 4way value 3 pos. tandem center
/ Hydraulics #6
Speed of operation is based on pump GPM , so if you pull the lever back, what happens?
/ Hydraulics
I have a concentric gear pump 4-8 GPM driven by 18 hp vanguard
/ Hydraulics
When lever is engaged pump squeals & motor bogs & cly move slowly
/ Hydraulics #9
You might put a hyd gauge in the valve and check out the pressure.
Is the cyl connected to anything and is it binding/bent, etc..
/ Hydraulics
Clys are connected toFEL bucket & bucket frame
/ Hydraulics #11
Remove the cyl hoses and place in a bucket and then operate the lever and see if fluid flows and the relief acrivates
/ Hydraulics #12
What is the rest of the story, did you put it on, did it ever work right?
Is it like this one from Kwik-Way?
Kubota AP-DZ3084 (A64126)
Kubota AP-DZ3084...
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
1143 (A63745)
1143 (A63745)
