Hydraulics
/ Hydraulics #1
Mcfclz
Bristol ct
Kubotab7100
I have a belt driven hydraulic pump on a case 442 with a FEL when ever I engage the value the pump squeals & motor bogs down. What is causing this & how could I correct the problem!! Your suggestions!
/ Hydraulics #2
Is there a pressure relief valve somewhere in the hydraulics?
It sounds like the pump is stalling due to low or dead headed flow.
If you ask a moderator to move this post to the the Hydraulics section in General Forums, or just post again there, you will get better and more help.
http://www.tractorbynet.com/forums/hydraulics/
/ Hydraulics #3
What is attached to the work ports on the valve?
If you are at the end of cyl travel, the relief will activate.
If a hyd motor is fully loaded, the relief will go off.
You may have a QD loose and can not pass the fluid to where it supposed to go.
If you have a cyl on the work ports, is the cyl moving.
/ Hydraulics
Work ports have cly connected, cly move very slowly when value is engaged
/ Hydraulics
I have a chief directional 4way value 3 pos. tandem center
/ Hydraulics #6
Speed of operation is based on pump GPM , so if you pull the lever back, what happens?
/ Hydraulics
I have a concentric gear pump 4-8 GPM driven by 18 hp vanguard
/ Hydraulics
When lever is engaged pump squeals & motor bogs & cly move slowly
/ Hydraulics #9
You might put a hyd gauge in the valve and check out the pressure.
Is the cyl connected to anything and is it binding/bent, etc..
/ Hydraulics
Clys are connected toFEL bucket & bucket frame
/ Hydraulics #11
Remove the cyl hoses and place in a bucket and then operate the lever and see if fluid flows and the relief acrivates
/ Hydraulics #12
What is the rest of the story, did you put it on, did it ever work right?
Is it like this one from Kwik-Way?
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (Trailer NOT included) (A63689)
Denyo DCA-600SPK...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
Vermeer S450TX (A64126)
Vermeer S450TX...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
2025 NEXHAUL N 714TA/DUMP T/A 14FT DUMP TRAILER (A59914)
2025 NEXHAUL N...
