Toplink HYDRAULIC TOP LINK
/ HYDRAULIC TOP LINK #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I was thinking about adding a HTL to a TC40 DA to allow me to cross a small shallow creek with relatively steep sides to improve the exit angle during the cross. I would be crossing with disc harrow or landscape rake to work food plots on the other side. Does this sound like it would help?? What are the downsides of HTL other than initial expense??
/ HYDRAULIC TOP LINK #2
From my perspective, there are NO downsides to owning a HTL. But - they won't lift implements any higher than a manual toplink of the same eye-to-eye length. The only difference is that you don't have to get off the tractor shorten a HTL before crossing a creek
//greg//
/ HYDRAULIC TOP LINK #3
An HTL will not increase the raised height of the implement over what the 3pt normally lifts. It's main function is to adjust the angle of attack of the implement's leading or trailing edge. This will raise either the front or back end of the implement but not raise the entire implement.
/ HYDRAULIC TOP LINK #4
A question to all out there with more tractor experience and knowledge than me. Can a hydraulic top link be used to apply "down pressure" to a post hole digger (PHD)?
/ HYDRAULIC TOP LINK #5
I think with most typical PHDs you remove the top link to attach them.
/ HYDRAULIC TOP LINK #6
Right you are, N80. But, I knew that, just had one of those brain f***s. Do you know of anything available that can be used to apply down pressure?
/ HYDRAULIC TOP LINK #7
ya there is a down pressure kit you can add....
/ HYDRAULIC TOP LINK #9
Schmisn, I can't read what is on that cylinder. Do you happen to know who makes it? Or, better yet, do they have a Website? If I could see a couple more pictures of that from different angles, I know I could build one like 3RRL suggested.
Would HTL allow you to more easily sharpen rotary cutter blades without removing them from cutter??
/ HYDRAULIC TOP LINK #11
I am not sure that you would want to use what we think of as a standard hydraulic for a home made down pressure kit. A factory purchased kit has built in safety valves for various reasons. Not saying that it can't be done, you would need to be careful and operate everything in a specific order or damage to the PHD could result. Look at the manuals section on the Land Pride website and you can see how to build one.
Hope that this helps
/ HYDRAULIC TOP LINK #12
MtnViewRanch, who makes the down pressure kits? I agree with you about the dangers involved, especially since I know next to nothing about working with hydraulics.
/ HYDRAULIC TOP LINK #13
The only ones that I know of for sure are Land Pride (which I just purchased 2 weeks ago) and Gearmore. I am not sure if they will work on someone else's PHD though. The are a bit pricey at over $500. :( I think that all the major brands most likely have them.
/ HYDRAULIC TOP LINK #14
The first time through your initial respnse, I missed your Land Pride reference. I went to their Website and found a local dealer. Sent an email to them asking for a price and asked if the kit is universal or a Land Pride PHD specific kit. I may send the same question to Land Pride. Thanks for your help.
I have an old auger that I bought at a farm estate sale and have no idea who built it. It has a heavy duty gearbox and I have twisted off a 10 inch bit with it. No damage to the gearbox, the frame, the tractor or me, thank goodness.
/ HYDRAULIC TOP LINK #15
No. As stated above, a HTL provides no vertical lift height advantage over a conventional toplink. The advantage is being able to change the geometry of the implement without leaving the tractor seat.
//greg//
/ HYDRAULIC TOP LINK #16
The pic in post 7 and 9 is a "DANUSER" brand phd. Been around a long time and make a very good product. Should be able to do a search for the web site with success.
/ HYDRAULIC TOP LINK #17
I just added weights ....kiss principle ya know?
/ HYDRAULIC TOP LINK #18
Actually, when you tighten a conventional toplink it does raise the tailwheel on a rotary cutter (by changing the geometry of course). So sure, raise the 3ph then close the hydraulic top link to get the rear of the mower angled up in the air for easier access to the blades. You can do this with a standard top link but much easier with a hydraulic one. However, this does not mean that you can get under a non-supported mower. The top link or the 3ph could lose pressure or leak down and crush you. Once you have it up, support it with jack stands or cribbing before you get under it.
/ HYDRAULIC TOP LINK #19
I'm curious, will that down pressure cylinder also help you pull it back out? Sure looks like it would.
/ HYDRAULIC TOP LINK #20
No, it has down pressure only. There is a valve that bleeds off as the PHD is lifted with the 3PH.
John Deere 5065E (A62180)
John Deere 5065E...
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
WACKER NEUSON LIGHT TOWER (A63569)
WACKER NEUSON...
Kubota M1085 (A62180)
SDLanch SDLE20 Mini Excavator (A62183)
SDLanch SDLE20...
