3-Point Hitch Hydraulic Top Link
/ Hydraulic Top Link #41
Another thing you could do is to use the diverter setup from the front. It's normal use is grapple functions. But w hoses going to the back, you'd have a nice easy way to control your htl. Especially if you have to nudge it a lot (depending on the attachment)
1 more option, using the detent remote on the back add a 2 spool or joystick valve mounted in the operator station and connect to the htl and side link. You'd be passing fluid through the valve just like the bh setup. Could do it with htl only and one spool valve...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
2016 PETERBILT PB320 GARBAGE/SANITATION TRUCK (A59823)
2016 PETERBILT...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
