hydraulic top link - is it worth it?
/ hydraulic top link - is it worth it? #21
I can tell you that as many times as I adjust the top link for when I'm doing serious box blade work, it would be worth it, and I'm going to add it.
I have to get on and off many times during the course of fair-sized job as I alternate using rippers, inside rear blade and rear outside blade to do different leveling or digging actions. A top cylinder alone would save me a LOT of work.
John
/ hydraulic top link - is it worth it? #22
John
/ hydraulic top link - is it worth it? #25
</font><font color="blue" class="small">( Here's a less expensive, although harder to use alternative. )</font>
Nothing came up but a bland page. Recheck your URL
John
/ hydraulic top link - is it worth it? #26
John
/ hydraulic top link - is it worth it? #27
With regard to selecting the right top-link length: Keep in mind that if you go to Pat's EZ-Hitch, it'll move the implement about 3" further back from the tractor. Therefore your top-link will have to be longer to get the same results.
After going to Pat's I find that my hyd. toplink is close to full extension most of the time.
Bob
/ hydraulic top link - is it worth it? #28
Bob
/ hydraulic top link - is it worth it? #29
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Here's a less expensive, although harder to use alternative. )</font>
John )</font>
I don't know it worked for me, just now.
The discusson was in customization and was entitled "ratchet jack for top link". /forums/images/graemlins/confused.gif
/ hydraulic top link - is it worth it? #30
John )</font>
/ hydraulic top link - is it worth it? #31
Just tried it again, and all I get is a page in customization that says page 1 or 1 but no thread! /forums/images/graemlins/confused.gif
Thanks.
John
/ hydraulic top link - is it worth it? #32
Thanks.
John
/ hydraulic top link - is it worth it? #33
</font><font color="blue" class="small">( With regard to selecting the right top-link length: Keep in mind that if you go to Pat's EZ-Hitch, it'll move the implement about 3" further back from the tractor. Therefore your top-link will have to be longer to get the same results.
Bob )</font>
It's funny how tractor brands differ when implements are purchased for them. On my Kama 554, the stock CCM hydraulic cylinder was too long for the 7" Howse boxblade, but when I added Pat's EZ hitch, it was just right. Now it tilts equally forwards and backwards....go figure??
/ hydraulic top link - is it worth it? #34
Bob )</font>
/ hydraulic top link - is it worth it? #35
I have read the posts and I am going to invest in a hydraulic top link. Now my question is do I need the one with or without the check valve. What are the pros and cons? I have rear hydraulics on my machine. Also with only one set of rear hydraulic connections how can I do a adjustable tilt also? (side to side)
/ hydraulic top link - is it worth it? #36
/ hydraulic top link - is it worth it? #37
</font><font color="blue" class="small">( Now my question is do I need the one with or without the check valve. What are the pros and cons? )</font>
I answered this in response to your post in another thread. But I'll do it again here to be consistent.
Cylinders with check valves are better than those without check valves. Most cylinders will leak down under load and both the top and tilt link cylinders are always under load. Check valves will prevent the leak down. So check valves will make your life easier. If you do a search here on TBN you will get literally hundreds of posts that discuss check valves and TNT systems. Read and you can decide for yourself.
</font><font color="blue" class="small">( I have rear hydraulics on my machine. Also with only one set of rear hydraulic connections how can I do a adjustable tilt also? (side to side) )</font>
Since you only have one set of remotes you can use a diverter to make one into two. A flick of a 12V momentary switch will select which part (the top or the tilt) will get fluid.
/ hydraulic top link - is it worth it? #38
/ hydraulic top link - is it worth it? #39
Thanks for the info and here is the next part of the question. Where can I get the diverter switch after market? I did some research from Deere and they want big bucks to install a diverter to work of the loader control. I am looking to do this off the 3rd scv on the rear. Thanks again
/ hydraulic top link - is it worth it? #40
2021 Deere 331G (A53317)
2021 Deere 331G...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Year: 2015 Make: Ford Model: F-550 Vehicle Type: Truck Mileage: 151,330 Plate: Body Type: Super Cab (A59230)
Year: 2015 Make...
2025 LandHonor RB-14-66W 66in Rock Bucket Skid Steer Attachment (A59228)
2025 LandHonor...
