hydraulic splitter sizing
   / hydraulic splitter sizing #11
Wayne County Hose said:
When splitting large diameters, the cylinder rod is not pushing straight out, the wood is trying to force the rod off of the cylinders centerline. The most common repair I see on log splitter hydraulics is a bent rod. All things being equal, or close to it, buy the splitter with the larger diameter rod.
Nice try, but swivels have nothing to do with the rod bending. They bend on a splitter because the rod is extended far out of the cylinder housing and more force is placed on the rod than it can handle. So, it bends. Kind of like pressing a 2"x4" piece of lumber against a wall. It doesn't matter what you do to the ends, it will bend in the middle.
The further the rod is extended, the easier it is for a catastrophe. The closer the piston gets to the gland, the easier it is for everything to bend. Same principal as an extension ladder, collapsed, it's very strong. Extend them all the way and they get shaky.
Cylinder manufacturers rarely have any input as to the engineering of the equipment their cylinders are manufactured for.
[[[As for no possibility of pressure higher than relief, you have got to be kidding me. When you have a gnarly piece of wood that builds pressure on the piston end approaching relief, then the wood pops, the piston goes flying forward, exerting all this force on the rod/gland end of the cylinder. I would bet that pressure spikes on the rod/gland end approach double the relief valve pressure.]]]
My post was to the 1st of your posts above. Perhaps I misunderstood your meaning. You dont seem to be supporting that post in the latest post, so maybe I did. The second post is on and off the mark; a] it is very important that the cyl body and the rod end float/pivot wrt each other so that the cyl axis and the extending rod can follow a straight line between 2 points, else flexure or misalignment in the assembly will cause a true bending moment, b] as you say, extension of the rod makes that 'straight line' more and more floppy, c] cyl manufacturers would be negligent to make generic pivot end cyls with rods too small to tolerate full extension/floppiness at full rated pressure with end mounts in decent alignment, d] [[[log pop will cause a quick acceleration of the ram, as you say, but that quick motion merely quickens the unobstructed flow of fluid from the small side back to the reservoir - so pressure on that side goes from 0 to 100psi maybe -- but for the sake of discussion, even if it transiently snapped above relief pressure it could not buckle the rod since pressure on that end counters rod extension - - only the seals would suffer]]], e] open tandem center valves such as used on loaders seal off the cyls when centered, so can allow very high pressure on cyls from bounce or push when the valve is centered. Splitter valves are plain open center, and vent both working ports to reservoir when centered - no overpressure allowed here.
larry
Thanks for all the insights, you've all been very informative especially considering my limited knowledge on this topic. Accordingly, I'll atempt to provider greater detail as to the intended usage.
Having installed the fireplace during construction in 2001, the building codes severely limited the number of choices, in fact this fireplace is actually considered to be a wood burning heater. Not only does it draw outside air for combustion, and has a blower to circulate the inside air around the firebox, it also has a catalytic converter that diminishes the byproducts of burning pine and the like. In any event, I'll still assess the deposit build up on the flue pipe on an annual basis.
All in all, it works extremely well and heats the home much faster than the propane alternative. The one draw back is that the fire box is small, and 14" is the longest stock that well reasonably fit and the max diameter is about 6 inches.
Considering that the bark beetle killed four beautiful 80' pine trees in the front yard, and we've burned most of the smaller stuff. I'm now contemplating the best way handling the larger stuff, there is also some eucalyptus that needs to taken cared of, all of the trees were cut more than two years ago. Since the weather on California's Central Coast isn't all that drastic, we use less than a cord per season. In total, there's probably six cords of wood.
Having missed the prime opportunity for cutting and splitting the eucalyptus, I'm somewhat dreading this task as I hear that it hardens as it seasons. What's the best way of doing this, is it best to cut and split what is needed for the current season, for to cut all the rounds and rent a splitter and store the wood. How should it be stored?
Also, it's my thought to use a splitter that can be used vertically, hence limiting the amount of heavy lifting. Northern Tool offers some reasonably priced splitters, that would make things more convenient than having to take the rental track.
Thanks again for your input.
   / hydraulic splitter sizing #13
larry
Have you ever had a pressure gauge on both the inlet and outlet of a cylinder at the same time? I can tell by this statement that you never have.
   / hydraulic splitter sizing #14
Well youre right. Ill have to try it. Cant see why thered be much on sump return ever cuz it wastes power and artificially limits the force available from the cyl. Also, with a std open center valve the cyl would extend in centered position if the return line pressure were high [even 100psi] since both inlet and outlet are connected to the return.
larry
   / hydraulic splitter sizing #15
I do it everyday.
Second pic is a Yanmar excavator cylinder undergoing a pressure test after resealing.
In a perfect, textbook world, the "drain" side of the cylinder would have zero pressure. Unfortunately, the world is not made of textbooks.
   / hydraulic splitter sizing #16
I would think with the small amount of wood that you are talking about maybe you should check your local rental places and see what it would cost to rent a spitter for a weekend project.
I am sure if you have all of the wood cut to size that it would be an easy task to split at least enough for a couple of years worth of wood burning.
Just my two cents?
Wayne
   / hydraulic splitter sizing #17
True that a rod can bend. I watched one bend on a shop built "shover" (used to push one piece of tubing inside another for a strengthener). Happened so fast that it was a 30 degree bend before the operator could stop it. Easily avoided by putting a simple strap 'loop' over the nose end of the cylinder w/ends welded to the armature.
While there may be some 'shock' from the block splitting suddenly, there will be no pressure 'spike' The instant the rod begins to extend, the pressure is on a rapid downward course. The rod will also not 'fly forward' - it won't move any faster than it will under no-load conditions (unless you have an air bubble somewhere in the pressure side).
Edit: The rod _can_ 'shoot forward' but only as far as the slack in the pin holes and in the slide will allow - a small fraction of an inch. That I have seen almost every time I split wood.
Harry K
   / hydraulic splitter sizing #18
[I]While there may be some 'shock' from the block splitting suddenly, there will be no pressure 'spike' The instant the rod begins to extend, the pressure is on a rapid downward course. The rod will also not 'fly forward' - it won't move any faster than it will under no-load conditions (unless you have an air bubble somewhere in the pressure side).[/I]
Harry K
Wow, 20+ years of training and experience down the drain.
   / hydraulic splitter sizing #19
turnkey4099 said:
Errm...no, the rating on the splitters is with the ram stalled, i.e., the max pressure the ram can exert. The size of the round has nothign to do with it.
Harry K
Uh yes Harry, there are 22 ton splitters out there (HF for example) that are "rated" for an 8" round which is absolutely silly and should not be a factor in deciding on a splitter. You didn't seem to notice when you said, "errm...no," but we do in fact agree.
As far as the cylinder rod bending outward it is called buckling and can happen even when both ends are pinned. Something has to give and the ram can buckle out if it is not adeqautely sized for the load.
   / hydraulic splitter sizing #20
Harry K
I agree with the main part of your post. This shoot forward thing tho has nothing to do with slack in the pins or slide. It is instead the release of energy stored in the mechanism - aka flex of beam, hose expansion, cylinder body expansion, ram compression, flex of the pins, fluid compression, torsion on the pump and engine shaft, etc. It all amounts, as you describe, to an extremely short movement. If the system relaxation occurs instantly there is an extremely short duration pressure spike on the unloaded side of the cyl. Look at it with an unfilled pressure gauge and youll see more of a pressure jump than there is. A fluid filled gauge would give better perspective. Many parts of the system would suffer if this instant release situation were prevalent, however it is very rare that this energy is released precipitously and so the detrimental effect falls in the noise. Maybe the splitter lasts 10 minutes less because of it. Altho a true effect, it is inconsequential here.
larry
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
1994 Aquasport Division boat with trailer (A55758)
1994 Aquasport...
