hydraulic pump
/ hydraulic pump #1
apache412
1954 ford NAA
I have a 1954 Ford NAA I just bought it and got it running after years of sitting and the 3 point arms don't raise, I have drained and refilled the case and blew into the dip stick hole to prime it and nothing I took the pipe plug off the piston type hydraulic pump and fluid came out with the motor running does this mean my pump is good? and I have problem some where else
/ hydraulic pump #2
Do you have a filter or screen that might be clogged?
/ hydraulic pump #3
That big fill cap under the seat is right by the hyd cylinder under the rockshaft cover. Take a look in there. Also check your fluid levels and possition/draft lever.
/ hydraulic pump #4
Under the seat. Its a big 2.5in cap with a square drive. There may be two. One back my the top link attachment.
/ hydraulic pump
yes that is the fill hole, what will I be looking for? fluid moving? it is full I already checked the level
/ hydraulic pump #6
Yes internal leaks. The pipe passes through the tranny as well. You may need to pop the shifter cover off.
Pulling the rockshaft cover would be my last resort.
/ hydraulic pump
ok I guess that will be this weekend before I get to that you are talking about the transmission shifter cover right?
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
1043 (A60430)
1043 (A60430)
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
