hydraulic pump
/ hydraulic pump #1
apache412
1954 ford NAA
I have a 1954 Ford NAA I just bought it and got it running after years of sitting and the 3 point arms don't raise, I have drained and refilled the case and blew into the dip stick hole to prime it and nothing I took the pipe plug off the piston type hydraulic pump and fluid came out with the motor running does this mean my pump is good? and I have problem some where else
/ hydraulic pump #2
Do you have a filter or screen that might be clogged?
/ hydraulic pump #3
That big fill cap under the seat is right by the hyd cylinder under the rockshaft cover. Take a look in there. Also check your fluid levels and possition/draft lever.
/ hydraulic pump #4
Under the seat. Its a big 2.5in cap with a square drive. There may be two. One back my the top link attachment.
/ hydraulic pump
yes that is the fill hole, what will I be looking for? fluid moving? it is full I already checked the level
/ hydraulic pump #6
Yes internal leaks. The pipe passes through the tranny as well. You may need to pop the shifter cover off.
Pulling the rockshaft cover would be my last resort.
/ hydraulic pump
ok I guess that will be this weekend before I get to that you are talking about the transmission shifter cover right?
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
(2) Electric Motors (A64127)
(2) Electric...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
