hydraulic pump
/ hydraulic pump #1
apache412
1954 ford NAA
I have a 1954 Ford NAA I just bought it and got it running after years of sitting and the 3 point arms don't raise, I have drained and refilled the case and blew into the dip stick hole to prime it and nothing I took the pipe plug off the piston type hydraulic pump and fluid came out with the motor running does this mean my pump is good? and I have problem some where else
/ hydraulic pump #2
Do you have a filter or screen that might be clogged?
/ hydraulic pump #3
That big fill cap under the seat is right by the hyd cylinder under the rockshaft cover. Take a look in there. Also check your fluid levels and possition/draft lever.
/ hydraulic pump #4
Under the seat. Its a big 2.5in cap with a square drive. There may be two. One back my the top link attachment.
/ hydraulic pump
yes that is the fill hole, what will I be looking for? fluid moving? it is full I already checked the level
/ hydraulic pump #6
Yes internal leaks. The pipe passes through the tranny as well. You may need to pop the shifter cover off.
Pulling the rockshaft cover would be my last resort.
/ hydraulic pump
ok I guess that will be this weekend before I get to that you are talking about the transmission shifter cover right?
Unverferth 330 (A64126)
Unverferth 330...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
2022 EZ-GO ELITE...
Used 20' Container (A62679)
Used 20' Container...
2012 International 4300 Reefer Truck (A63689)
2012 International...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
