hydraulic pump
/ hydraulic pump #1
apache412
1954 ford NAA
I have a 1954 Ford NAA I just bought it and got it running after years of sitting and the 3 point arms don't raise, I have drained and refilled the case and blew into the dip stick hole to prime it and nothing I took the pipe plug off the piston type hydraulic pump and fluid came out with the motor running does this mean my pump is good? and I have problem some where else
/ hydraulic pump #2
Do you have a filter or screen that might be clogged?
/ hydraulic pump #3
That big fill cap under the seat is right by the hyd cylinder under the rockshaft cover. Take a look in there. Also check your fluid levels and possition/draft lever.
/ hydraulic pump #4
Under the seat. Its a big 2.5in cap with a square drive. There may be two. One back my the top link attachment.
/ hydraulic pump
yes that is the fill hole, what will I be looking for? fluid moving? it is full I already checked the level
/ hydraulic pump #6
Yes internal leaks. The pipe passes through the tranny as well. You may need to pop the shifter cover off.
Pulling the rockshaft cover would be my last resort.
/ hydraulic pump
ok I guess that will be this weekend before I get to that you are talking about the transmission shifter cover right?
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Hesston 3717 4 Basket Hay Tedder (A66408)
Hesston 3717 4...
Informational Lot - Financing (A63689)
Informational Lot...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
