Hydraulic pressure testing
/ Hydraulic pressure testing #1
Haneyman
John Deere 3038e
John Deere 3038E with D160 loader, no third function or remotes.
Looking for a hydraulic pressure tester.
Kens bolt on hooks only has for the two series.
Any help appreciated,
Thanks,Mike
/ Hydraulic pressure testing #2
I would email Ken, and ask if he can fit one up for you. I think he can, as he has other size hydraulic connects.
If not, buy the gauge (Ken or Amazon), a hydraulic hose and the required fitting at TS, Amazon or local shop, and make one up yourself.
/ Hydraulic pressure testing #3
If you are looking for loader pressures use the hydraulic quick connects they are the easiest to match when you are building your gauge. I prefer T-ing into the line so I can see pressures as the attachment works. instead of just dead heading the system at the quick connect.
/ Hydraulic pressure testing #4
The E model has no quick couplers, the loader isn't quick disconnect. That's why the OP sent the pictures.
I bet the 2 and 3 series tractors have the same size hydraulic lines for the loader.
Using a T and installed permanently, the gauge can also be used as a scale. Just need to associate the displayed pressure with weight.
Don't cheap out on the gauge if permanently installed. If the gauge fails and leaks you're stuck dead.
/ Hydraulic pressure testing #5
leave it to deere to cheap out on the simplest upgrades. So I guess the loaders are not removable (atleast easily)
kind of hard to identify fittings when they are still attached.
Was hoping to find a kit. Surely I’m not the only 3038E owner wanting to add a gauge.
thanks
/ Hydraulic pressure testing #7
The E stands for "economy" and it is you get what you pay for. Want deluxe, go to the R series. Get to pay for the "extras".
Find a connection where you can put in a "T" and plumb your pressure test gauge in there. Take notes from member Bavarian, he said it well. Have some fun with it. Will be a nice upgrade. It's what I did to my wood splitter, to see the pump pressure when splitting oak firewood.
2022 FORD F-250 XL SUPER DUTY CAB & CHASSIS (A67714)
2022 FORD F-250 XL...
213138 (A64276)
213138 (A64276)
2020 Ford Explorer AWD SUV (A66738)
2020 Ford Explorer...
2007 CHEVROLET MALIBU CAR (A66091)
2007 CHEVROLET...
2002 12ft Haulmark KD7X16WT2 Cargo T/A Enclosed Air Cascade Trailer (A66738)
2002 12ft Haulmark...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
