hydraulic fluid
/ hydraulic fluid #1
dalsup
detroit,texas
kubota l2600dt
where do i check the hydraulic fluid level on a kubota l2600dt tractor?
/ hydraulic fluid #2
Unless yours is different it should have a site glass on the left side of the tranny sort of behind the clutch pedal. Park on level ground with engine off and implements on the ground. Oil level should be half way in the glass.
/ hydraulic fluid #4
It should have 3 drain plugs. The main is right under the shifter under the floor board. It should be easy to see when you get under there. Look at the drop down part of the rear end. It will have a drain plug on both sides of the lowest part of the rear end.
Caterpillar 980B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980B...
HARDEE 4R SPRAYER (A63291)
HARDEE 4R SPRAYER...
Honda EM6500SX Generator (A62613)
Honda EM6500SX...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
Caterpillar Service Letters from 1960's (A63117)
Caterpillar...
7002SFL (A61572)
7002SFL (A61572)
