Hydraulic Fitting ID?
/ Hydraulic Fitting ID? #1
Lucky Dog
Midland, MI
TYM 4820c
I blew a hydraulic line on my old Massey Ferguson loader. I believe it is a Model 100 loader.
None of my local shops can ID nor do they have one of the fittings.
I'm hoping someone here can give me an ID?
/ Hydraulic Fitting ID? #2
It looks like some type of flare rather than a separate fitting...
I'm not sure I follow?
It does look like some sort of flare, but it is all one piece crimped onto the hose.
Here is a pic of the entire thing.
/ Hydraulic Fitting ID? #4
Looks more like an automotive oil fitting than hydraulic. Merc oil cooler lines
/ Hydraulic Fitting ID? #5
Is there an o ring in the female end? I've seen stuff like this in oil and AC applications just not in hydraulic, but there is always a first.
/ Hydraulic Fitting ID? #6
I did find this but it's aluminium and for AC I believe. Now they "may" been made in steel years ago and work for Hydro. I don't know and YMMV but it may provide a clue.
Boy, that does look similar. Mine is steel.
There was no o-ring on it when I took it apart.
That does not mean it should not have though. Some one in the hydraulic shop asked the same thing.
/ Hydraulic Fitting ID? #9
If you have to improvise...compression type fittings may be an option using the original end...If the tube part is a typical size...
I have a feeling that someone "improvised" on this already. That is how this part got in there. :)
/ Hydraulic Fitting ID? #11
OK that type of fitting is called beadlock and can be had in steel as well. I have NO clue on what they are rated for, other than AC on older vehicles using R12. I know Merc used it for oil lines at times.
/ Hydraulic Fitting ID? #13
Easy to fix for me, just cut off the end and silver braze a common end on and crimp a new hose on it. Yes it should have an Oring on it.
/ Hydraulic Fitting ID? #14
I have conversion adapters for those, it will allow making standard hoses, measure the thread dia, TPI and pm me for more info.
/ Hydraulic Fitting ID? #15
“Easy to fix for me, just cut off the end and silver braze a common end on and crimp a new hose on it. Yes it should have an Oring on it.”
I use female braze ons to make crimp hoses if clearance is an issue.
/ Hydraulic Fitting ID? #16
Grind the compression sleeve off, slide new sleeve on old fitting & press the new sleeve. Hydro shop should be able to do it.
/ Hydraulic Fitting ID? #17
Yes, it is called a beadlock fitting it should have had an o-ring for a seal.
They were used for a lot of lower pressure hydraulic lines years ago.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
Unverferth 6225 (A64119)
Unverferth 6225...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A61572)
2007 JLG 600HJ...
2013 Honda Pilot SUV (A61574)
2013 Honda Pilot...
