Hydraulic Fitting ID?
/ Hydraulic Fitting ID? #1
Lucky Dog
Midland, MI
TYM 4820c
I blew a hydraulic line on my old Massey Ferguson loader. I believe it is a Model 100 loader.
None of my local shops can ID nor do they have one of the fittings.
I'm hoping someone here can give me an ID?
/ Hydraulic Fitting ID? #2
It looks like some type of flare rather than a separate fitting...
I'm not sure I follow?
It does look like some sort of flare, but it is all one piece crimped onto the hose.
Here is a pic of the entire thing.
/ Hydraulic Fitting ID? #4
Looks more like an automotive oil fitting than hydraulic. Merc oil cooler lines
/ Hydraulic Fitting ID? #5
Is there an o ring in the female end? I've seen stuff like this in oil and AC applications just not in hydraulic, but there is always a first.
/ Hydraulic Fitting ID? #6
I did find this but it's aluminium and for AC I believe. Now they "may" been made in steel years ago and work for Hydro. I don't know and YMMV but it may provide a clue.
Boy, that does look similar. Mine is steel.
There was no o-ring on it when I took it apart.
That does not mean it should not have though. Some one in the hydraulic shop asked the same thing.
/ Hydraulic Fitting ID? #9
If you have to improvise...compression type fittings may be an option using the original end...If the tube part is a typical size...
I have a feeling that someone "improvised" on this already. That is how this part got in there. :)
/ Hydraulic Fitting ID? #11
OK that type of fitting is called beadlock and can be had in steel as well. I have NO clue on what they are rated for, other than AC on older vehicles using R12. I know Merc used it for oil lines at times.
/ Hydraulic Fitting ID? #13
Easy to fix for me, just cut off the end and silver braze a common end on and crimp a new hose on it. Yes it should have an Oring on it.
/ Hydraulic Fitting ID? #14
I have conversion adapters for those, it will allow making standard hoses, measure the thread dia, TPI and pm me for more info.
/ Hydraulic Fitting ID? #15
“Easy to fix for me, just cut off the end and silver braze a common end on and crimp a new hose on it. Yes it should have an Oring on it.”
I use female braze ons to make crimp hoses if clearance is an issue.
/ Hydraulic Fitting ID? #16
Grind the compression sleeve off, slide new sleeve on old fitting & press the new sleeve. Hydro shop should be able to do it.
/ Hydraulic Fitting ID? #17
Yes, it is called a beadlock fitting it should have had an o-ring for a seal.
They were used for a lot of lower pressure hydraulic lines years ago.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
1986 INTERNATIONAL 1900 FLATBED TRUCK (A63291)
1986 INTERNATIONAL...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
