HVAC Decision Time
/ HVAC Decision Time #21
Bmac,
Installation is more important than brand. I personally know a large Trane dealer here whose installation techs do not pull a vacuum on the refrigerant lines and evaporator before start up. They use a technique called "blow & go". They simply blast refrigerant vapor through the evaporator coil to purge the air and then open the service valves and start the unit. The proper procedure as I was taught is to pull a triple vacuum with the final pulldown at 500 microns. Many installers do not even have a micron gage on their trucks these days. There are other installers of other brands who use the "blow & go" method as well, I only mention the Trane dealer to show that just because you purchase a big name unit does not automatically insure quality installation.
You need to be confident your contractor will be there in 1-5 years in the event you have a warranty issue. Mechanical equipment can and will break, and the more bells and whistles you have, the higher the likelyhood of problems. I personally like to keep it simple when it comes to residental HVAC equipment and see little value in spending mega-bucks on super high SEER, variable speed fans, multi-stage compressors, two stage gas valves & burners, etc. and electrostatic air filters. (Unless someone in your home has severe allergies requiring special air filtration). As I stated in a previous post, I am of the firm belief that the best money value is spent on a high quality air distrubution and return air ducting system.
Now if you truly desire the bells and whistles type system and believe the value is there, then that is what you should purchase.
I'm curious if you have looked at rhe Ruud/Rheem brands which are manufactured in Milledgeville, Ga.?
/ HVAC Decision Time #22
</font><font color="blue" class="small">( Murph,
The quote I referred to was for a 4 ton on the main floor and 3.5 ton for upstairs. Does the $4500 increase for the 14 SEER still seem unreasonably high? )</font>
Yes to me it does sound high. Now if he is going from a 12 SEER R22 to a 14 SEER Puron system it may not be so bad. PM me with the model numbers he is referring to and I will give you my costs difference between the 2.
And Cityboy's comment about different makes versus dealers is valid. Our service techs all have vacummn pumps and micron gauges. Pick one of the three big ones and make sure your dealer is great, just like buying a tractor, dealer has to be good.
murph
Cityboyfarmer,
I did not look at other brands. Took the advice of a cousin who owns a HVAC company in FL. He said if he were building a home, he would install American Standard / Trane.
I don't have the time or energy to research every brand of every component going into this house. Therefore, I am relying on advice from folks I believe are more knowledgable than myself to help in the decision-making process. I've already commited to the Trane equipment. Air handler in the attic was supposed to have been installed yesterday. I still have time to decide between dedicated heat/AC and dual fuel heat pump.
I believe you 100% that there are probably other brands that are equally capable and that probably cost less. And, as with most things, I also do not doubt that proper installation is the key to success. I have no idea about the particular installation technique my HVAC sub is using, however.
My home builder is actually a father-son team who are well-respected in the area. I know people who have had homes built by them and they are very pleased with the final product. One family is so pleased that they are going to have them build another home. The subs my builder uses, for the most part, have been with them for years. He stays with them because they tend to do a good job and he doesn't have to go back after closing and cover for their mistakes. The son of this father son team is building a home for himself now and is using the same subs and systems we are using on our home. In fact, when questions arise, we usually say "just do what you would do in your home". Are they perfect? Absolutely not. We have had a few issues come up. But for the most part, they have handled them to our satisfaction.
I guess the point I am trying to make is that I am placing a lot of trust in my builder to use subcontractors that are going to do a good job. I am paying quite a premium for this level of trust. However, I also know that, with enough money, improvements could be made. For example, they are using the insulated flexible ductwork. I've seen shows on TV where each section of ductwork was custom fabricated from rigid material. My budget just won't allow me to be that particular. However, I do expect to be comfortable during all seasons and would like to do so in a reasonably energy-efficient manner. Like you, I don't see the financial benefit of going to the most energy efficient systems - the markup is just too great. I'm looking for something toward middle of the road in efficiency.
I do appreciate your feedback and recommendations. I am probably too far into this to take advantage of most of it.
/ HVAC Decision Time #24
</font><font color="blue" class="small">( Cityboyfarmer,
I did not look at other brands. )</font>
bmac,
The Trane product is one of the top three or four. Don't worry about it's realiability. In fact they are the only manufacturer left that builds it's own compressors. If you trust the dealer then your set.
murph
/ HVAC Decision Time #25
Bmac,
You will be fine with the Trane. Even if the sub falls off the planet, you can still get warranty service if needed, just as you can with any reputable manufacturer.
<font color="blue"> Our initial quote was for a 12 SEER AC. To bump this up to a 14 SEER is an additional $4600.00 (this is for 2 units - upstairs and main level) </font>
Well, there was a miscommunication between the HVAC subcontractor and myself re: prices. I know some thought something was askew with these so, now that I have them in writing, I thought I would post a correction.
The base price included a single speed blower. To go to a variable speed blower on each of the 2 units is an additional $2450. Then the upgrade to the 14 SEER AC is $2200 (again, for 2 units - one 4 ton, one 3.5 ton). If you add those 2 upgrades together, you get the $4600 that I had originally posted.
The upgrade from the 12 SEER AC to the 14 SEER dual fuel heat pump is $3400.
Murph, are these figures more in line with your prices?
/ HVAC Decision Time #27
BMAC,
Let me get this straight, 2400 to go to a variable speed blower on the furnaces or air handlers??
2200 to go from a 12 seer to a 14 seer may be in line if your going from a R22 system to a puron system.
Again, PM me your actual model models or email me your quote and I will give you my actual costs on these items. This way I can be more helpful.
murph
/ HVAC Decision Time #28
The contractor should of given you an estimate on 13 S.E.E.R equipment as well.
Some equipment lines, if not all, require variable speed to reach a 14 S.E.E.R rating (along with that good old TXV valve not installed that everyone LOVES /forums/images/graemlins/mad.gif)
Not always the case with 13 S.E.E.R (needing a variable speed blower).
You guys remember the good old Carrier days when a variable speed motor ran $500? /forums/images/graemlins/grin.gif
And per thcri (what happened to "Murph"?), you need tm differentiate between a 410A sxstem and R-22 system. A 410A system will run you more money by far.
/ HVAC Decision Time #29
I am making a similar HVAC system decision. I just received a quote for Trane dual-fuel with a R410A based heat pump for installation near Norcross, GA.
Why would one choose an R410A refrigerant over R22?
One reason choosing a new R22 based system could cost more in the future for some reason you must replace the outside unit after year 2010, you will end up replacing the inside coil too. Is that even a valid scenario?
Otherwise, I don't understand why one would choose to pay the premium for a R410A system in 2005. I mean, I lean in a earth friendly green direction but currency green is of value to me as well.
/forums/images/graemlins/confused.gif
/ HVAC Decision Time #30
<font color="blue"> As for the cost of propane, you mentioned the increase in NG. Here in PA, the propane is following the increases in NG, so no matter what gas you use, it is getting expensive.
paul
</font>
Not that this is the way it is back East or at least not yet, but out West we use hydro, nuclear, natural gas turbines, a few coal plants, solar/wind to generate power. An increase in NG is an automatic increase in electricity. Our electricity is not cheap, it is pretty much our last choice to heat with. Some folks go all electric and get a break from the utility company, something I have yet to understand as it seems those who choose gas pay to offset the smaller amount of those who choose all electric and since we are tied as to who transmits and distributes our power have little options.
/ HVAC Decision Time #31
Why after 2010 would you need to replace your indoor coil if you need to change your outside unit?
410A at this time is more than R22, but after this year, goverment will "mandate" production of R22 until 2020, at which point R-22 will no longer be produced.
You will start to see a decrease (price) in 410A as production increases, and an increase in R22 and production decreases.
/ HVAC Decision Time #32
I am not speaking against R410, but be aware that R22 for service and repair will be available long, long after 2010. Production will stop, but all of the recovered/recycled gas wioll be available for sale. Today it is no problem to get R12 at reasonable prices, and R22 will be tha sema.
paul
/ HVAC Decision Time #33
Currently R22 is 10 times more per pound than R-22.
Late 90's R12 was pushing $1200 for a 30lb jug /forums/images/graemlins/shocked.gif
I honestly don't thinkg that R410A is the "way to go", but...as manufacturers increase production of 410A units, pricing will come down, and vise versa for R-22 units.
It will come down to economics as far as the contractor is concearned which unit is an "easier sell" (to the homeowner). At this point, R-22 units are cheaper, but...a couple of years from now that will not be the case.
/ HVAC Decision Time #34
Where can you get R 12 at a reasonable price ? What is a reasonable price ? $1500.00 - $1800.00 per 30 lb ! Not reasonable to me .
/ HVAC Decision Time #35
On ebay you can get 30 lb R12 cylinders for $ 200~$300. Prices at the wholesaler are not too much higher. After the R12 ban the prices did spike, but have been coming down ever since. The R22 market should not be anywhere as volatile since this has been a slow phase out with a well developed replacement market. Also the reclaim/recycle industry has been around many years and is mature.
paul
/ HVAC Decision Time #36
I don't know if I would buy from e- bay. No telling what may arrive. I was talking to a guy at an auto repair shop back in the summer . There were several 30lb containers of what appeared to be R 12. I asked if he had gotten a good deal on it . He said that someone came by while he (the owner) was out & offered to sell aeveral containers of R 12 for $100.00 ea. One of his employees thinking that he was getting his boss a good deal purchased them (I think it was 8 or 10 jugs) ,it turned out to be R 22 labeled R12 & painted white.
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
2012 Ford F-550 4x4 Terex Hi-Ranger LT40 40FT Insulated Bucket Truck (A59230)
2012 Ford F-550...
2015 Ford Transit 150 Cargo Van (A59230)
2015 Ford Transit...
Topsoil Trommel (A57453)
Topsoil Trommel...
