Husky air compressor problem
/ Husky air compressor problem #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I have had a Husky air compressor from home depot for about a year or so now. The other night, it would not pump up higher than 60 psi. It has a 5.5hp motor w/ a 26 gallon tank. Any ideas? It is oilless motor, maintenance free. Can't seem to figure it out. /forums/images/graemlins/confused.gif
/ Husky air compressor problem #2
Two potential problems come to mind.
1. Worn cylinder rings (not likely if you have average usage in the past 1.5 years)
2. Stuck reed valve.
/ Husky air compressor problem #3
Or a broken reed valve. As I've mentioned before, if you have a manual and a place of obtain parts, you can completely rebuild one of those in well under an hour. Does the manual include an exploded view? And does someone else, such as DeVilbiss, build them for Husky and Home Depot? A broken reed valve was the first thing that happened to my oilless Craftsman and the parts would have cost about $13.00 if it hadn't been still under warranty.
What type of noise did it make? Mine sounds like an exhaust leak. There are no air leaks when I shut it off.
/ Husky air compressor problem #5
When mine had a broken reed valve, it didn't sound any different except that it could run continuously and never get above 30 psi. I'd never be able to diagnose yours just from us trying to verbally describe the sounds, but you probably have a broken or stuck reed valve although it's possible that the teflon has worn off the cylinder or the piston ring is worn out. Any of those things are simple to fix if you have the parts.
Thanks for the help, Bird. I was considering a new compressor!
/ Husky air compressor problem #7
Let's hope we're not overlooking the simplest thing first. /forums/images/graemlins/laugh.gif You say it sounds like an exhaust leak? Have you checked the pressure relief valve to make sure it isn't what's leaking? I wouldn't think that would be likely, but quite possible.
/ Husky air compressor problem #8
Deere, I hope you aren't thinking of PAYING for a new compressor! The cheapest compressor should last more than 2 yrs even under heavy use and abuse!
I have a husky in the garage that has seen sparse use--bought it in 1975 and although the tank has rusted out (and I patched it once), it still works. I had to get a bigger one to paint with, but this is still functioning. 30+ yrs!
ron
/ Husky air compressor problem #9
make sure the line from the compressor to the tank is not cracked or loose at the fittings . There should be a fitting in the tank . The line from the compressor goes into this fitting. On my compressor it is a check valve & only lets air into the tank but, not . If this line or fitting is cracked , you would hear air leaking when the compressor is running but, not when it shuts off.
/ Husky air compressor problem #10
I bought a Craftsman oiless and used it less than a week before it quit pumping. I took it back and bought a regular Capmbell Hausfeld that I've now had over 10 years and it still works as new. I prefer the old "oiled" type, it's a lot quieter too!
PS I'm betting on a broken reed valve too.......
I'm going to try to tear it apart this weekend and I'll let you guys know what I find. Thanks a milion for all the help!
/ Husky air compressor problem #12
</font><font color="blue" class="small">( Deere, I hope you aren't thinking of PAYING for a new compressor! The cheapest compressor should last more than 2 yrs even under heavy use and abuse )</font>
I agree.. I've got a chinese pancake compressor i paid 80$ for 6 ys ago.. I've use dthat thing plus and extra air tank to paint 3 tractors. in some cases, the unit was running continously.... that other unit should last longer.. though I'm not a fan of those high -db oil less compressors. Ever compressor I've seen ditched was either due to a motor failure ( oil type pump ).. or a cyl failure... ( oiless )..
Soundguy
Found the problem...apparently, some dirt got in the cylinder and tore the piston ring and really put some grooves in the cylinder. Anyone know how much it would be to fix? I think, if I can, I will just replace the entire head. Maybe I should just buy a new one? /forums/images/graemlins/confused.gif
ATS Mini Excavator (A66285)
ATS Mini Excavator...
2716SFL (A61567)
2716SFL (A61567)
Transfer tank (A61567)
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
