HST Power ?
/ HST Power ? #21
OP isn't treating the hydro pedal like a gas pedal.....right?
(i.e. don't push pedal down more as tractor slows down, instead lift pedal for the "shift to lower gear" equivalent.)
He wouldn't be the first.
THANK YOU
I have mentioned that several time on here and never seen an response
/ HST Power ? #23
Must be a misprint. Not 146 drawbar HP.
Massey Ferguson 1749 Engine
Mitsubishi K38, turbocharged intercooled diesel, 3-cylinder, liquid-cooled inline, 101 ci [1.7 L]
Power: 48.3 hp [36.0 kW]
Drawbar: 146.65 hp [109.4 kW]
Bore: 3.386×3.74 inches [86 x 95 mm]
Air Cleaner: dry element
Compression: 16.5:1
Rated RPM: 2500
Starter volts: 12
/ HST Power ?
THANK YOU
Good points about the linked throttle and the HST pedal not being an acceleration pedal. It took me a bit to realize that the transmission needs higher rpm to work properly and to get the feel of using the HST pedal. When working it hard I have the throttle set at PTO rpms and monitor the tach to control the HST pedal position. When the rpms start to drop I back off the HST pedal until the rpms get back to PTO speed. It's a balancing act and I have that figured out.
With the HST I can keep the rpms up but have to watch the HST pedal position in order to maintain the rpms
As you can see I have already addressed the Hydro pedal position.:)
There is no red line or PTO info on this tach. Basically it just shows the rpm's. I checked the owners manual and can't find the max rpm info but this tractor will only rev to about 2510 max and that is where I run it when working it hard.
FredH thanks for that link. As D2Cat suggested there must be a misprint about the drawbar HP. I wish it were true though because if it was I wouldn't have any problem dragging my little boxblade.
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2020 Solar Tech Silent Advisor S/A Solar Towable Radar Trailer (A61572)
2020 Solar Tech...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
213140 (A64276)
213140 (A64276)
STORAGE FEES (A59914)
