HST Power ?
/ HST Power ? #21
OP isn't treating the hydro pedal like a gas pedal.....right?
(i.e. don't push pedal down more as tractor slows down, instead lift pedal for the "shift to lower gear" equivalent.)
He wouldn't be the first.
THANK YOU
I have mentioned that several time on here and never seen an response
/ HST Power ? #23
Must be a misprint. Not 146 drawbar HP.
Massey Ferguson 1749 Engine
Mitsubishi K38, turbocharged intercooled diesel, 3-cylinder, liquid-cooled inline, 101 ci [1.7 L]
Power: 48.3 hp [36.0 kW]
Drawbar: 146.65 hp [109.4 kW]
Bore: 3.386×3.74 inches [86 x 95 mm]
Air Cleaner: dry element
Compression: 16.5:1
Rated RPM: 2500
Starter volts: 12
/ HST Power ?
THANK YOU
Good points about the linked throttle and the HST pedal not being an acceleration pedal. It took me a bit to realize that the transmission needs higher rpm to work properly and to get the feel of using the HST pedal. When working it hard I have the throttle set at PTO rpms and monitor the tach to control the HST pedal position. When the rpms start to drop I back off the HST pedal until the rpms get back to PTO speed. It's a balancing act and I have that figured out.
With the HST I can keep the rpms up but have to watch the HST pedal position in order to maintain the rpms
As you can see I have already addressed the Hydro pedal position.:)
There is no red line or PTO info on this tach. Basically it just shows the rpm's. I checked the owners manual and can't find the max rpm info but this tractor will only rev to about 2510 max and that is where I run it when working it hard.
FredH thanks for that link. As D2Cat suggested there must be a misprint about the drawbar HP. I wish it were true though because if it was I wouldn't have any problem dragging my little boxblade.
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
Woods Rotary Cutter (A63116)
Woods Rotary...
Case 586H 4wd Off road forklift (A63118)
Case 586H 4wd Off...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
832655 (A61165)
832655 (A61165)
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
