hp/ft cutter requirements
   / hp/ft cutter requirements #1
southerndeere
My dad and I are looking to upgrade from our current 353 series kuhn cutter to a 4000 an upgrading tractors. Local jd has a 6150m and a 6170r. We have always went by the 10hp/ft of cutter. The local sales rep an my dad say the 6150 is fine which I know it will be but I have always had the idea of more is better. And the 6170 is not much more money. I don't get on here but I like hearing what other people think.
   / hp/ft cutter requirements #2
If youre talking about bushog type cutters, 10HP/ft is awesome on a heavy duty cutter that has a gearbox rated 2 to 3 times that. I have a lightweight 5' HD cutter made by JD in the 60s. Ive used it from 9hp/ft down to 4hp/ft. Its hard to imagine where more than 10/ft would be needed. ... Maybe thick grass?
,,,larry
Its a discbine for hay. An someof the grass does get pretty thick when it raina a lot and we can't cut it as often.
   / hp/ft cutter requirements #4
The 10hp/ft is a good rule of thumb for a discbine. The reason why it has higher requirements than a brush cutter is the speed at which it is effectively used is higher, and the weight of the tractor takes a good bit of HP to move at a fast pace.
   / hp/ft cutter requirements #5
Ah-h ... They condition too dont they?
Took a while but we finally bought the 6170. Suppose to be delievered to farm Tuesday an if rain holds off we will be cutting with it.
   / hp/ft cutter requirements #8
I think you made the right move. You can never seem to have to much hp with a discbine.
I agree. It may have been a lil much when we were looking at a 13 ft kuhn. But we didn't buy it an now my dad is looking at a 956 deere. That is a big mower an we will need all of that 6170 I'm sure.
199049 (A51243)
199049 (A51243)
WB Mower (A50120)
WB Mower (A50120)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
