kenmac
Super Member
- Joined
- Feb 13, 2005
- Messages
- 9,964
- Location
- The Heart of Dixie
- Tractor
- McCormick CX105 Kubota MX 5100 HST,
size ? I have 40 acres here and have a MX5100 HST 4WD. It does all I need to do, and it does it very well
Never operated HST, but nobody seems to have anything bad to say.
What is your "procedure" for going down hill ? Presume with FEL on the front?
I've gone to two different dealers and told them the same thing. They have both advised almost identical size tractor in terms of HP.
Love to know what you suggest.
I have 20 acres with the majority in pasture grass so bush hogging is the main thing. None of it is flat with one or two quite steep hills. It is a dairy farm that hasn't been worked or maintained in years so pastures are a bit rough. Some woods on steeper parts but only 3 acres of so. I'll cut and haul some firewood but probably get it out with a winch
I want to move some dirt as well so planning on backhoe and FEL.
I'm in middle Tennessee so snow isn't really an issue. And, I don't have a long gravel drive to maintain. I
I am getting a bit older and want to save my back, etc by not doing as much manual work as I used to.
Given that, what would you recommend for HP? Advice very much appreciated!
Make sure the tractor is in 4 WD, FEL is about 1 foot (or less)off the ground, always travel straight up and straight down and never try to turn on a steep hill. With HST, just back off the pedal to slow the tractor and if really steep and speed picks up, lightly ride the brakes (both).Never operated HST, but nobody seems to have anything bad to say.
Heck For cutting grass / pasture , I use the Kubota ZD1021. It does a better job and I can cut faster than using the brush cutter with my large tractor
I have 20 acres, 17 acres in pasture grass. Nothing flat. One or two steep hills. Some woods on steeper parts but only 3 acres. It is a dairy farm that hasn't been maintained so pastures are rough.
Bush hogging is the main thing. I want to move some dirt. Planning on backhoe and FEL.
I am getting older and want to save my back.
What do you recommend for HP?
Teachu2; POST #8;5052710 said:As much as I found a backhoe attractive, I realize Backhoe is not as practical as it appeared. Backhoe has to be off the tractor to use the three point hitch, and 95% of the time I'm mowing, or using the box blade. I'd have to store it, mount it, dismount it, and pay for it - for a piece of equipment I'd rarely use and was an inferior tool when I did use it.
An HST transmission is a fluid pump.
The higher you set the engine speed, the more fluid it will pump, and, the more you press the directional pedals, the more fluid will flow from that pump to a hydraulic motor that is attached to the drive system.
The pump works with a swash plate. It's at a 90 degree angle when not moving. You step on the pedal a bit, and the angle changes and it pumps fluid. The more you step on the pedal, the greater the angle of the swash plate, the more fluid it pumps and the faster you go. If you let your foot off the pedal, the swash plate returns to 90 degrees and the tractor stops moving. If you step in the reverse pedal, the swash plate angles in the other direction, and pumps the fluid backwards, which turns the hydraulic motor backwards, which turns the drive system backwards.
Fluid cannot be compressed. So when you let off the pedals, the fluid cannot flow through the system, and it effectively locks the machine in place.
So going down a hill, you want your engine RPMs up as high as they'll go, so you have more responsive hydraulics, which = responsive hydraulic braking when you let off the pedal. It won't freewheel down the hill and it shouldn't pick up speed. You should be able to let off the directional pedals and it will stop itself.
In fact, some machines are kinda brutal as to how fast they'll stop if you whip your foot off the pedals. My old IH2500b had a circuit to soften the hydraulic braking effect.
My current machine is all hydraulic and it doesn't even have brakes; only a parking pin.
Hope that helps explain it a bit. :confused3:
This thread is germane to your search:
http://www.tractorbynet.com/forums/...ons/384070-need-tractor-advice-pics-land.html
"The doggone German's ain't got nothin to do with this!"
- Sherriff Buford T. Justice, Smokey and the Bandit....![]()
I too use my 52" Ferris IS 750 to mow my 6 acres of pasture sometimes and I can do it faster than I can with my 7 foot bush hog and get everything even right up against the trees. I cant get the tractor in to some of the places with trees. The Ferris is also smoother on the rough ground than the tractor.
MossRoad, that's a great explanation of a basic single range variable speed HST transmission. And theoretically all any tractor needs is just a basic single range HST transmission. But that's theory. Lucky for us gadget guys, there's there's a lot more that a HST transmission is capable of doing. This may sound like a adv. but it's not; transmissions fascinate me and I haven't seen one yet to compare to Kubota's HST+.
The Kubota HST+ transmission can be operated manually just like MossRoad explains - but it also has a fancy computer aided mode.
Now HST+ doesn't have to be operated in fancy mode. It can be worked all day just using the HST pedal and hand throttle exactly as MossRoad explained. Used that way, the HST+ will stay in a single range & the throttle is adjusted manually. I've done it that way a few hours just to remind myself how HST used to work when it first came out. But HST+ also has some more features.
1. To start with, HST+ has 3 selectable ranges plus a selectable high/low in each range. THe ranges are always manually selected, but the High/Low can be manual, manual override, or let the tractor choose.
2. The tractor will automatically look after itself with varying loads if the operator wants it to. Push a button on the dash, and the HST+ does this by comparing HST pedal position against engine RPM. It will then automatically advance the throttle to match the load, apparently it will even automatically shift between high and low range if needed.
3. Anytime it is in load sensing mode if there is no load, then the tractor automatically returns the engine to idle. I sure like this. On one brand of tractor I had to move a lever to idle every time I let off on the HST pedal. With HST+ this happens smoothly and automatically. All user selectable through that same dash switch.
4. Finally the hydraulic braking effect of any HST tranny that MossRoad refers to is adjustable with the HST+. There is a dial on the dash that allows you to vary the HST response rate from slow to fast. Best to tighten the seat belt before setting it to "fast".
My hat's off to those guys....Kubota made one very clever transmission.
rScotty
You want to be in the 40hp-60hp frame size, whatever make and model you consider. Highly recommend HST, just easier all around. :thumbsup:
In the same vein, I occasionally do some brushhogging for the welding shop down the road with our L3830. He also has had someone with a Ford 4000 (or similar size) tractor, there are many of the softer areas where the lighter (and 4 wheel drive) L3830 will float through and but the heavier 2 wheel drive Ford would sink in and get stuck.While I agree with most points in this thread, I will say there are upsides to more horsepower in the smaller frame tractors. May have been mentioned but I didn't thoroughly read every post.
Everyone keeps saying that without the weight of a big frame machine that the extra power is wasted. If you're brush hogging, I disagree. For dirt moving and ground work, yes, weight helps a lot, but if your primary use is brush hogging then extra power to spin a larger unit would come in handy.
More power also lets you get through thicker brush without bogging down.
Just something else to consider. Just make sure you have enough weight out front to keep the nose down!![]()
