kenmac
Super Member
- Joined
- Feb 13, 2005
- Messages
- 9,931
- Location
- The Heart of Dixie
- Tractor
- McCormick CX105 Kubota MX 5100 HST,
size ? I have 40 acres here and have a MX5100 HST 4WD. It does all I need to do, and it does it very well
Never operated HST, but nobody seems to have anything bad to say.
What is your "procedure" for going down hill ? Presume with FEL on the front?
I've gone to two different dealers and told them the same thing. They have both advised almost identical size tractor in terms of HP.
Love to know what you suggest.
I have 20 acres with the majority in pasture grass so bush hogging is the main thing. None of it is flat with one or two quite steep hills. It is a dairy farm that hasn't been worked or maintained in years so pastures are a bit rough. Some woods on steeper parts but only 3 acres of so. I'll cut and haul some firewood but probably get it out with a winch
I want to move some dirt as well so planning on backhoe and FEL.
I'm in middle Tennessee so snow isn't really an issue. And, I don't have a long gravel drive to maintain. I
I am getting a bit older and want to save my back, etc by not doing as much manual work as I used to.
Given that, what would you recommend for HP? Advice very much appreciated!
Make sure the tractor is in 4 WD, FEL is about 1 foot (or less)off the ground, always travel straight up and straight down and never try to turn on a steep hill. With HST, just back off the pedal to slow the tractor and if really steep and speed picks up, lightly ride the brakes (both).Never operated HST, but nobody seems to have anything bad to say.
Heck For cutting grass / pasture , I use the Kubota ZD1021. It does a better job and I can cut faster than using the brush cutter with my large tractor
I have 20 acres, 17 acres in pasture grass. Nothing flat. One or two steep hills. Some woods on steeper parts but only 3 acres. It is a dairy farm that hasn't been maintained so pastures are rough.
Bush hogging is the main thing. I want to move some dirt. Planning on backhoe and FEL.
I am getting older and want to save my back.
What do you recommend for HP?
Teachu2; POST #8;5052710 said:As much as I found a backhoe attractive, I realize Backhoe is not as practical as it appeared. Backhoe has to be off the tractor to use the three point hitch, and 95% of the time I'm mowing, or using the box blade. I'd have to store it, mount it, dismount it, and pay for it - for a piece of equipment I'd rarely use and was an inferior tool when I did use it.
